Strange Fuel Pump Relay Issue - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-20-2010, 03:27 PM Thread Starter
Date registered: Sep 2010
1988 420SEL. It's been a wonderful car except for one annoying problem. Intermittently the engine starts & dies, starts & dies. I pull the fuel pump relay out and replace it with a spare I have and it fires right up. It may be fine for a week or two and does it again. Go through the same routine and it fires up and drives fine. Sometimes I can just pull it out and pop it back in and it runs fine.
Is this a case of two intermittent relays by coincidence or something else going on. Pins in socket look fine. Someone said there may be a solder joint inside the relay module that was a known defect (?) I'm fairly competent at elctronics & wiring so not afraid to take it apart if it's something I can fix. Or should I just chalk it up to two bad FP relays?
Seattle_Mike is offline
    2003 C320 Relay Chart? Fuel pump relay location? Cooop General Mercedes-Benz 0 03-01-2010 07:56 AM
    300E-W124 Fuel Pump Relay- Overvoltage relay Homebrewer For Sale/Wanted/Trade/Giveaway 0 08-09-2009 06:17 AM
    85 380SE fuel pump relay issue ScottP General Mercedes-Benz 3 03-30-2009 05:38 AM
    1980 280SLC 4sp - fuel pump relay issue? willreed1 R/C107 SL/SLC Class 9 02-12-2009 01:19 AM
    fuel pump relay issue jwc W126 S,SE,SEC,SEL,SD,SDL Class 4 02-16-2008 01:02 PM
