Hello I'm David & I'm new and need some help! - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-16-2010, 08:42 AM Thread Starter
Date registered: Sep 2010
I'm new to the site and need help? Driving my wife's 2001 ml320 home the other day it stalled out of nowhere. Tried starting it back up and wouldn't crank. Noticed a check engine signal was on earlier in the week but it drove fine. All instruments lights came on when I turned the key on but no firing. Had it towed to the mb dealership and the tech said it needed a new aam/master key but couldn't be sure! No error messages available. $841 later problem still the same. New key locks/unlocks the door but won't start the engine. Red light under low range is working. Now the tech says the new key isn't "waking-up" the m.e. but insn't sure. Want's another $1,400 to see if it will work.?.? Had the fuses checked and #14 isn't energizing? Starting system was checked by another garage and seems to be fine. Don't know if it's a relay problem or what?? Starting to loose it, can somebody please h.e.l.p. Thanks DMOTZ.
dmotl8 is offline
    David & Goliath Zmog Unimog 5 01-10-2008 09:01 AM
    David Plaine DP Off-Topic 4 10-27-2006 03:00 PM
    hello david.... Tan W163 M-Class 14 11-20-2001 11:42 AM
    For David... Arnee R170 SLK-Class 1 12-27-2000 03:26 PM
    David, can you please switch your name? You have the same as me..... David R170 SLK-Class 3 12-06-2000 08:34 PM
