C220 cdi not starting - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-14-2010, 07:09 AM Thread Starter
Date registered: Sep 2010
Hi i have a 2002 c220 cdi with 72000 miles. I tryed to start my car this morning. When i turned the key all the lights come on but it did not turn over? Also the wipers where not working but every thing else was fine!
I left it over night and when i came out today (the next day) It fired up fine it is working a ok and i just dont understand it. can someone shed some light on this problem many thanks Alan
Alan Stevens is offline
post #2 of 5 (permalink) Old 09-14-2010, 08:29 AM
Kajtek1's Avatar
Quoted: 1059 Post(s)
Judging from the description you must be in England?
Those engines were never sold in USA, where most of the members are from.
Not knowing your car, I can have general guess that your battery is getting weak. When voltage drops below certain mark, the computer will not engage the starter and on some models will disable comfort items to save the energy.
Other might be bad neutral switch on the transmission, or bad clutch switch if you have manual.
Welcome to the forum.
Kajtek1 is online now
post #3 of 5 (permalink) Old 09-14-2010, 10:56 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
Sounds to me that there is at least something in addition to a bad battery if the car started fine later on while the battery was not charged meanwhile.
Anyway a bad battery may prevent the drive current to the starter motor. It can be from the solenoid not having enough power to engage or the starter relay or some bad contacts at the front SAM.
Would be useful to know if there was a good "click" sound from the starter motor solenoid or a faint "click" from the starter relay or no sound at all.
Diesel Benz is offline
post #4 of 5 (permalink) Old 11-13-2010, 09:42 AM
Date registered: Nov 2010
Hi. I am from England and I too have a problem with my wiperblades not working. They did work for the wiper fluid but when you switch them on they do not work at all. Later they did not even work for this. I thought it may have been a fuse but that is fine. any suggestions? The car is a c220 cdi 2006/07
Wasif1980 is offline
post #5 of 5 (permalink) Old 11-13-2010, 11:13 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Are you sure you checked the right fuse(s)? Sometimes they can be bad but not look like it. It's always best to check them with a multi-meter.
Musikmann is offline
    C200 cdi v c220 cdi are they same engine? h9llw W203 C-Class 2 01-03-2011 01:35 PM
    1995 c220 not starting, not cranking, then OK rmaxwell2191 W202 C-Class 2 07-30-2010 07:05 PM
    C220 Automatic CDI Not starting simonbe General Mercedes-Benz 6 08-31-2009 02:47 PM
    c220 cdi help!!! stevewilson General Mercedes-Benz 1 03-21-2009 07:30 AM
    C220 CDI kevin b Benzworld Site issues forum 0 01-23-2009 04:29 AM
