Help, problems with my W126 S-Class - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-11-2010, 09:24 PM Thread Starter
Date registered: Mar 2010
When stopped at stop lights for extended periods of time I get a skunky gas smell in cabin, it is somewhat moderate but very noticeable. When I pull the car into the garage and close the overhead door and leave the car in there the skunky gas smell fills the garage. Does anybody have an insight into what is causing this? Any similar experiences? My mechanic fixed what I believe he called a fuel injector pan but it did not solve the problem. I'm concerned it might be a head gasket issue
1989W126 is offline
    85 W126 ignition switch problems Honda858 W126 S,SE,SEC,SEL,SD,SDL Class 1 10-31-2006 10:42 AM
    w126 starting and idle problems MishaZ W126 S,SE,SEC,SEL,SD,SDL Class 8 03-14-2006 05:45 AM
    W126 Transmission problems Htown W126 S,SE,SEC,SEL,SD,SDL Class 2 05-15-2005 03:17 PM
    Common W126 Problems [H] Spetsnaz Op W126 S,SE,SEC,SEL,SD,SDL Class 3 04-14-2003 04:08 PM
    1991 300SE(w126) Radio Problems Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 4 07-16-2001 04:21 AM
