W115 280 won't start need help and diagrams - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-08-2010, 03:04 AM Thread Starter
Date registered: Mar 2009
hello guys,
i will try to explain as much as possible.
bought the car like this, was told it had a problem, supposidly the fuel pump had gone, tested and no power coming to fuel pump.
i then check for a pulse at the injector plugs and nothing, tested the trigger switch in the distrubitor and it seems to be working.
i then undid the connector going to the ecu and there is no power anywhere.
it is sparking and when cranked it would momentarily start but not keep running, meaning that the cold start was working.
there are extra wiring harness and a switch inside the cabin suggesting that this car was once fitted with a lpg system.
i really am in need for some wiring diagrams for the engine wiring harness and ecu connector.
jak4cars is offline
post #2 of 2 (permalink) Old 09-27-2010, 05:01 AM Thread Starter
hello again,
i'm still in need for any wiring diagrams for this w115, i especially am after diagrams for ecu and ecu relay.
just because everything seems to be working except for power coming to the ecu
cheeers
jak4cars is offline
    Just bought this mint 1974 280 w115 Lamakdaddy Vintage Mercedes-Benz 12 07-23-2009 01:15 PM
    Armored 280 CDI - power/torque diagrams Zé Bocaina G-Class 0 09-07-2008 09:44 AM
    F/S W114/W115 (230, 250c, 280, 280c) Literature Mike Doiron For Sale/Wanted/Trade/Giveaway 3 01-19-2008 11:10 AM
    Difference between 280(W114) and 230(W115)? Gazolba Vintage Mercedes-Benz 2 10-07-2006 05:25 AM
    70 280 S wiring diagrams Rales Vintage Mercedes-Benz 0 01-17-2005 01:12 PM
