NEED HELP! water draining? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-07-2010, 10:53 PM Thread Starter
Date registered: Sep 2010
Vehicle: Mercedes 180E - 1992
Exclamation NEED HELP! water draining?
Hi all Benz owners!
I have a 1992 180E - W201. It is a great car but we just had a massive rain/storm but everytime a turn a corner now i hear water rolling around somewhere??? I was wondering if you guys might know where the water might be and where/how i can drain it. How are the drainage holes found. and for some reason all of my windows are fogging up over night and don't know why... is it because of the water build up in the car somewhere or is it something else?
jamesony is offline
post #2 of 5 (permalink) Old 09-08-2010, 09:01 AM
Kajtek1's Avatar
Vehicle: w211 E320 wagon 4M / Bluetec / Ford SD. Seeking affordable diesel pushmower
Quoted: 1044 Post(s)
The cabin doesn't have any drainage holes. No water suppose to enter it period. Sunroof has drains coming down to inner fender per my knowledge, but I never had a problem with them.
If your car collected some moisture inside -park it on the sun with all door opens and floor mats removed for 1/2 day.
Make sure you will not drain the battery with the cabin lights on.
Kajtek1 is online now
post #3 of 5 (permalink) Old 09-08-2010, 09:55 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Sometimes the drains in the doors get clogged with debris if the car is parked outside all the time and water pools inside the doors. See if the drains are clear.
'59 220S Cabriolet - for sale -
'83 240D original owner 351,500 miles - for sale -
'88 560SL 41,000 miles being parted out -
'99 E300 turbo 196,000 miles
'03 SLK320 34,500 miles
'14 Smart electric
sokoloff is offline
post #4 of 5 (permalink) Old 09-08-2010, 10:28 AM
Date registered: Apr 2008
Vehicle: 97 E320
Send a message via AIM to stewmeistr
I am not familiar with your car per se', but I have a 97' w210 and it does the same thing. I never thought of it being part of the Sunroof assembly, but just like you, after a good rain it will have water pool and subsequently "slosh" on starts and stops in what sounds like the rocker panels. I would agree with the suggestion that something is clogged, but what I have found that works on my car is to open the black plastic "discs" that are under the car with a screw driver wedged up inside. This will allow a slow drain.
Secondly, there is a black plastic (seems like a 2" drain tube) on the underside of the car on each side near the rear wheels. I took the same screw driver and stuck it up inside that tube. Instant drainage. You just want to get out as much junk and H2O as possible for obvious reasons.
Good luck, hope this helps.
stewmeistr is offline
post #5 of 5 (permalink) Old 09-08-2010, 09:18 PM Thread Starter
thanks everyone for your replies! they have come in handy and will do what you have all recommended.
jamesony is offline
    Battery keep draining! help! max_speed97 W220 S-Class 21 07-30-2014 08:44 AM
    No AC condensation draining JohnMichael W140 S-Class 4 08-30-2013 06:57 PM
    battery draining! baudenfj W124 E,CE,D,TD Class 6 02-21-2010 04:38 PM
    Water not draining 300dster W123 E,CE,D,CD,TD,TE Class 2 02-12-2010 07:29 AM
    Water not draining ehil500 W211 E-Class 11 09-19-2009 03:21 PM
