Brakes - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-07-2010, 04:28 PM Thread Starter
Date registered: Feb 2009
Brakes
I recently changed my 2006 C350 brakes after the visit repair shop warning came on. I bought a set of Duralast brakes and they did not have the opening to plug in a sensor. Is there any way to remove the warning light message with brakes installed with no brake sensor opening.
rford78 is offline
post #2 of 4 (permalink) Old 09-07-2010, 08:31 PM
Kajtek1's Avatar
Quoted: 1226 Post(s)
Do you have picture of the sensors? All MB sensors I know are single wire grounding to the rotor when it comes close to it. Meaning no sensor = no light EVER.
I had situation on Audi, where 2 wires sensors are breaking the circuit. Cutting off the wires of old sensor and connecting them together did the trick.
Kajtek1 is offline
post #3 of 4 (permalink) Old 09-08-2010, 09:52 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Don't worry, in a thousand miles or so, you'll be replacing those brakes once the squeaking drives you crazy. You can then put pads in that do have the sensors.
Len
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - sadly I let it go
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 207,000 miles
'03 SLK320 37,500 miles
'14 Smart electric 9700 miles
sokoloff is offline
post #4 of 4 (permalink) Old 09-08-2010, 10:15 AM Thread Starter
Thanks to you both, currently the front has no sensor so Im going to check the back brakes and see how they look although I had a shop change them a year ago. If they are not worn then I know they did not replace my pads/shoes.
THanks
rford78 is offline
    Buy my stuff , getrag swap/400e brakes/c36 brakes/strute bar veedubfreak86 For Sale/Wanted/Trade/Giveaway 0 08-23-2010 06:29 PM
    Brakes Question (Changing my Brother in-Laws Brakes, Just to be sure) Donkeykongohio W203 C-Class 3 11-27-2009 09:20 AM
    2003 C230 Sedan brakes to 2004 cross-drilled brakes? aaronmarks W203 C-Class 1 10-05-2005 04:00 PM
    SL500 brakes and e55 rear brakes sonofworf1 R170 SLK-Class 0 08-15-2003 10:24 PM
    Upgrading to Brembo or Porsche brakes? I will buy your W202 AMG brakes from you! Guest (MBNZ) W202 C36 AMG, C43 AMG 1 05-11-2002 02:11 PM
