C230 1997 Brake light switch removal - Page 3 - Mercedes-Benz Forum
post #21 of 26 (permalink) Old 09-24-2010, 04:49 PM Thread Starter
Date registered: Dec 2006
Vehicle: 2002 E320
Keyhole, you were right on the target. Benz dealer told me ETS control module is bad on this car and it would cost $1002 to replace it. Cost of the module is $825. Now I am thinking I should pay them the diagnostic charge and replace the module myself. First question, is this easy to do and what is involved. On the other hand if I can not get a good price by shopping on the internet, then I guess I should go ahead and get it done by the dealer. Thanks. I am really impressed with your knowledge and diagnosis.
Riazcriaz is offline
post #22 of 26 (permalink) Old 09-25-2010, 05:01 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 410 Post(s)
Jeez.... that's a big financial jump from simply replacing your brake light switch...
I can attach some technical info about the location and function of your ESP control unit - but unfortunately my WIS does not give the information on how to remove it. It looks quite obvious, and is easy to access in the engine bay.
However, as I see it, you are over a barrel here with MB as they have advised replacement of an expensive electronic module, which they will not accept in return if you fit it - and it is not the real fault. That non-return policy for modules seems to be common. We have it also in the UK.
In your shoes, for peace of mind I guess that I would (reluctantly) let MB take it from here on. If they change the module and it does not fix the problem, you will not be out of pocket. If you did source a cheaper N47/5, would it have a warranty? Also, (although not stated in my WIS, as there is no procedure) on other module change-outs described in my WIS, there is always the requirement to hook up to the MB STAR diagnostic system before the job is completed. So probably you would have to hand it over to MB after your own work, anyway.
As you will see, it is clamped directly to the Traction control hydraulic unit (A7/5) - the item with 6 hydraulic lines attached. Maybe the N47/5 cover has to be removed first to show the bolts that are holding it to A7/5.
Let us know how it all works out
keyhole is offline
post #23 of 26 (permalink) Old 10-06-2010, 11:24 PM Thread Starter
Vehicle: 2002 E320
Well, MB has to special order the ETS module because they say it is very rare for it to fail. They put it in today and the problem was fixed. Thanks again for every body. keyhole you were great and definitely a diagnostic Guru.
post #24 of 26 (permalink) Old 10-07-2010, 12:16 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
You should have asked the dealer to give back the old ETS module to keep as a $800 souvenir.
mbvis is offline
post #25 of 26 (permalink) Old 10-07-2010, 04:44 AM
keyhole's Avatar
Quoted: 410 Post(s)
I'm very pleased to read that your problem is now solved....
Of course it would have been more satisfactory if you had been able to do the work entirely at home and save a few bucks - but sometimes in life we have to accept the inevitable.
Sleuthing through your problem here has been an interesting exercise for me also, especially as I have most of the same parts in my CLK and I could find myself in the same boat one day!
This thread, I think, shows our forum at its best, as we struggled with the 'unknown' and eliminated other possible causes. Clearly, you could have put you car into a shop on day 1, but what would we DIY enthusiasts have learned from that?
keyhole is offline
post #26 of 26 (permalink) Old 11-23-2010, 01:04 PM
Date registered: Apr 2009
Thanks for a great thread - it really helped me with my BAS/ASR light problem. I was hoping it was something obscure but inexpensive...I removed the brake switch and carefully took it apart. The bottom "NC" contact leaf had broken - a smoking gun as far as diagnosis was concerned. $32 part at the dealer and the BAS/ASR light is off and everything is working as it should. Thanks again!
jimjazzdad is offline
Brake light Switch Removal 2004 S500 4matic darkeyedangelz W220 S-Class 1 08-17-2010 09:20 AM
Wtb 1997 c230 mirror switch mpelchen For Sale/Wanted/Trade/Giveaway 1 03-11-2010 12:07 AM
Ignition switch removal 1997 C230 nokkieny W202 C-Class 0 09-27-2009 10:50 AM
1997 C230 Window/Mirror Switch mpelchen W202 C-Class 6 03-09-2009 01:13 PM
Brake light switch removal E240 estate brocklesby W210 E50 AMG, E55 AMG 0 11-21-2005 04:02 AM
