Diesel primary fuel filter - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-05-2010, 01:02 AM Thread Starter
Date registered: Jul 2010
Vehicle: 2003 C240
Hi
I have a 2009 E280 CDI W211, Where is the Diesel Primary Fuel Filter and how do I change it?
Many thx
samjesse is offline
post #2 of 8 (permalink) Old 09-05-2010, 09:10 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Underneath the engine top cover.
Change it according to WIS instructions.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 8 (permalink) Old 09-05-2010, 01:00 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 410 Post(s)
I think you have slightly missed the point here... folks that ask questions here generally do not have a WIS..
Anyway sam, for a 642 engine:
1. pop the plastic engine cover
2. remove the engine air intake duct - downstream of the air filter
3. note the fuel filter, left of center near the front, with circular top.
4. disconnect the 2 fuel lines
5. loosen retaining bolt
6. remove filter assembly.
keyhole is offline
post #4 of 8 (permalink) Old 09-05-2010, 01:55 PM Thread Starter
Vehicle: 2003 C240
don't I need to prime the system after that since the air will get in?
samjesse is offline
post #5 of 8 (permalink) Old 09-06-2010, 01:19 AM
keyhole's Avatar
Quoted: 410 Post(s)
My WIS does not say that, but as it is intended for use by trained mechanics, maybe that is assumed.
I have no diesel engine experience. When is priming normally required?
keyhole is offline
post #6 of 8 (permalink) Old 09-06-2010, 03:27 AM
Diesel Benz's Avatar
Quoted: 40 Post(s)
Most often it should be enough to fill up the filter can and then just crank the engine.
Diesel Benz is offline
post #7 of 8 (permalink) Old 09-07-2010, 07:54 AM
Quoted: 2 Post(s)
... the alternative of getting incorrect information--as yours is--is not acceptable.
You've omitted dealing with CLIC clamps and that's important.
The REAL point is, if you want to do DIY you still have to have the tools and the most important tool is access to factory procedures. It's simply foolish (and often dangerous) to do anything else.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #8 of 8 (permalink) Old 09-08-2010, 07:59 AM
keyhole's Avatar
Quoted: 410 Post(s)
You sound a bit peevish here... There's nothing incorrect in my post. Where clamps are required to remove a fuel filter (when under the car) the WIS will refer to them. Here it does not.
Do you really think that fuel will flow upwards from the tank and gush out of these lines? Apart from what is inside the lines there should be very little loss of fuel when the lines are pulled off.
The guy asked where the filter was, and how to change it. I told him. No special tools are required here. He didn't ask about the pitfalls, torques, etc. If it gets complicated, I post the entire WIS page that contains such information.
This is just a forum where we try to help out fellow MB owners...
keyhole is offline
Diesel Fuel Filter carl6405 W210 E-Class 27 06-06-2010 09:02 PM
Diesel Fuel filter change James_413 V-Class 3 12-03-2008 10:47 AM
Diesel Primary filter clogging curbill W123 E,CE,D,CD,TD,TE Class 6 03-03-2008 02:57 PM
primary fuel filter 85 300d elrod817 W123 E,CE,D,CD,TD,TE Class 1 12-05-2006 11:50 AM
primary fuel filter (spin on) banditele W123 E,CE,D,CD,TD,TE Class 30 03-16-2005 11:26 AM
