Battery voltage - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-30-2010, 01:10 PM Thread Starter
1carguy's Avatar
Date registered: Feb 2010
Vehicle: '16 GMC Canyon, '09 C300,'66 Mustang cnvrt-High Cntry Spl,'01 Mustng Cobr, Elec.golf car-35 MPH!
Quoted: 5 Post(s)
Smile Battery voltage
I've seen several post's regarding low battery voltage.
What would the minimum voltage be for an auto battery - at what battery voltage will the electronics begin to malfunction and cause problems/false indications?
If confusion is a destination . . . . we have arrived.
1carguy is offline
post #2 of 8 (permalink) Old 08-30-2010, 01:20 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
The first problem to occur with low voltage will be failure to turn the starter motor.
Anything past that isn't too relevant, I'd think.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 8 (permalink) Old 08-30-2010, 03:08 PM
Musikmann's Avatar
Quoted: 6 Post(s)
From what I've read on here, lower than optimal battery output voltages can cause various electrical gremlins and /or trouble lights and might even set diagnostic trouble codes too. And if I remember correctly, these symptoms can occur when the battery still has enough juice to start the car. How low the threshold has to be is anyone's guess but I suspect it's somewhat different from one model to another and dependent on what type, and how many, power consuming options it has.
Musikmann is offline
post #4 of 8 (permalink) Old 08-30-2010, 05:54 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
This should be correct for the cars mentioned at the OP's profile but dual battery cars like the W211 can give the low battery warning from a bad AUX battery while the car would still start fine.
Diesel Benz is offline
post #5 of 8 (permalink) Old 11-20-2012, 12:09 PM
Date registered: Nov 2012
I would like to know what the optimum voltage really should be. I've read that a weak battery can cause w251 power tailgate problems. My tailgate motor is not running and I'm reading 12.8v. I'm thinking that's a little low, but would like to know for sure before replacing the battery.
Clambake is offline
post #6 of 8 (permalink) Old 11-20-2012, 01:07 PM
Triggerhappy's Avatar
Date registered: Nov 2009
Vehicle: 1978 240D
Quoted: 41 Post(s)
With the engine off your battery should be between 12 and 14 volts. If it stays around 12 it is probably time to replace it. With the engine running it should be at 13-15, optimally 14. If it's 13 or below and the engine has been running for a while it might be a bad alternator.
Triggerhappy is offline
post #7 of 8 (permalink) Old 11-20-2012, 03:09 PM
Date registered: Jul 2012
Vehicle: 07 E63 + 07 CLK63 Cab
Engine off with good battery reading should be 12.3-12.5 volts
Engine running actually loaded with minimal accessories 14-14.2 at idle
Same 14.2 when above idle and everything on.
12.8 not running is high but fine and the problem is probably the gate motor.
Load test would cover all bases
my critter is offline
post #8 of 8 (permalink) Old 11-20-2012, 03:51 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 404 Post(s)
I just picked up a brand-new Varta battery today, which is fully charged. The voltage at the terminals is 12.68v.
I know that if the battery voltage is 12.1v it is 50% discharged, and at 11.7v it is fully discharged. However, the alternator will maintain the terminal voltage at 14.2 v while the engine is running.
The starter may still work with the battery at 10.0v - 11.0v. At 7.0v the ECU will inhibit cranking.
keyhole is offline
voltage at the battery bill-costa rica Unimog 5 02-17-2010 03:36 PM
Battery voltage check 1catand1dog W210 E-Class 9 11-10-2009 08:09 AM
i need help in checking battery voltage aaraisi W203 C-Class 10 10-31-2008 02:54 AM
obtaining battery voltage denperkins W210 E-Class 1 10-09-2008 01:50 PM
Battery voltage display?? MillTek W163 M-Class 0 02-12-2007 09:11 PM
