Would you replace these tires? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-28-2010, 04:06 PM Thread Starter
Date registered: Jan 2004
Quoted: 34 Post(s)
These are Goodyear tires, three years old with 28,000 miles on them. The cracking/dry rot in them have me concerned. I would lean to replace them even though they are still showing about 6/32nds of tread. What are your thoughts?
Name:	Element tires 001.jpg
ID:	327702   Click image for larger version
Name:	Element tires 004.jpg
Len
'59 220S Cabriolet - for sale - http://www.bruceadams190sl.com/1959-...20s-cabriolet/
'83 240D original owner 351,500 miles - sadly I let it go
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 207,000 miles
'03 SLK320 37,500 miles
'14 Smart electric 10,500 miles
sokoloff is offline
post #2 of 6 (permalink) Old 08-28-2010, 04:47 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 405 Post(s)
6/32nds is only about 50% wear (new is 10/32nds, done is 2/32nds)
However that rubber looks 'perished' - even at the base of the tread, and I would ditch the tire. My opinion is that the manufacture is defective for the rubber to degrade in such a manner before it is worn out. Maybe a bad batch here.
What does you tire supplier say about this condition?
keyhole is offline
post #3 of 6 (permalink) Old 08-28-2010, 07:33 PM
Date registered: Jun 2009
Replace them.
Pembroke36 is offline
post #4 of 6 (permalink) Old 08-28-2010, 07:50 PM
Kajtek1's Avatar
Quoted: 1289 Post(s)
How do you know they are 3 years old? Read the DOT number to confirm.
There is no way tire can deteriorate that much in 3 years even parked on desert. If it did it is manufacturing defect and subject to recall.
Kajtek1 is offline
post #5 of 6 (permalink) Old 08-28-2010, 07:56 PM
Xander Crews's Avatar
Date registered: Aug 2010
Vehicle: '97 Land Cruiser
I'd replace them. As the others have said...they look older than three years. :2cents:
Xander Crews is offline
post #6 of 6 (permalink) Old 08-28-2010, 08:18 PM Thread Starter
Quoted: 34 Post(s)
Thanks for the replies guys. My initial reaction was that they needed to be replaced too, but I've never run into this situation before. Date code on the tires is '07 and they came new on the car, so they are in fact three years old.
Len
sokoloff is offline
time to replace tires s430owna C215 CL-Class 2 09-17-2008 02:21 PM
Replace tires now allignment problem freshwater W163 M-Class 4 03-27-2006 07:41 PM
About to replace noisy tappets, anything else we should replace at the same time?? busters the boy! W124 E,CE,D,TD Class 6 06-15-2005 11:17 AM
I need to replace tires what size should I get Maras G G-Class 4 12-21-2004 12:57 PM
How lond did your original set of tires last? What did you replace them with? Chris - CA Bay R170 SLK-Class 1 09-03-2002 02:10 PM
