Help Needed & Question 560SL - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-27-2010, 04:39 PM Thread Starter
Date registered: Aug 2010
Vehicle: 1987 560SL
I had a problem with my engine and have repaired it how ever while confused during repair I touched an adjustment and should not have. My question is how do I re-adjust the setting of the air adjustment located through the hole in the top of the air filter cover. I think this is an air adjustment. The car seems to be running OK, maybe a little rough since I touched this. I moved this adjustment with an Allen wrench. Does this just change the idle or does it also effect high RPMs?
Thanks Gary
dandy89@verizon.net
gary919 is offline
post #2 of 4 (permalink) Old 08-27-2010, 06:04 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
How did you get to it it is usually sealed, the ajustment is usually done thru a exhaust analyzer and is referred to as lambda. It affects the mixture, that is why it is sealed
Peter Guenther is offline
post #3 of 4 (permalink) Old 08-27-2010, 07:33 PM Thread Starter
Vehicle: 1987 560SL
Air adjustment
I got to it by removing the seal, not a smart idea but I do stupid things like that. So what you are saying is I cannot adjust it back. I did not move it more then a turn then I moved back I hope. Is it a very sensitive adjustment?
Gary
gary919 is offline
post #4 of 4 (permalink) Old 08-29-2010, 02:39 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Gary
Yes, you can adjust it back and yes, it's pretty sensitive. Ideally you want to do this with an exhaust analyzer, so you can have an idea how rich you're making it. You can try it by feel/sound, but it seems like that's what got you in the predicament you're in.
flyboyike is offline
1988 560SL AC help needed Fastshivy R/C107 SL/SLC Class 17 07-14-2010 10:53 AM
560SL brake help needed- what am I doing wrong? W126Ken_W.Pa R/C107 SL/SLC Class 5 05-02-2010 01:56 AM
Wheel/Tire Help Needed - '87 560SL new2benz2 R/C107 SL/SLC Class 11 09-17-2009 05:26 PM
87 560SL advice needed! swmtb R/C107 SL/SLC Class 20 09-02-2009 09:59 AM
Oppinions needed re 560sl Fharoah R/C107 SL/SLC Class 6 04-02-2007 10:36 AM
