ASR problems... - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-27-2010, 12:16 AM Thread Starter
Date registered: Aug 2010
Vehicle: 1994 Mercedes Benz E 320
Exclamation ASR problems...
Hi everyone, I have a 1994 E320 which the ASR light has come on and along with it I have my stereo that blinks on and off when the car is running, I also hear a slight clicking noise inside the car and that's when the headlights dim. When I shut the car off the radio plays fine. When I first start the car everything is okay for a bout 5 seconds then the ASR light comes on and everything starts happening. Could anybody help me with this?
John
ekwok@bellsouth.net is offline
post #2 of 7 (permalink) Old 08-27-2010, 01:53 AM
Date registered: Dec 2008
Vehicle: 1993 190E 2.6, 1990 300SEL, 1992 300SE, 1992 400E, 1987 190E 2.6 murdered by my brother.
Hey John have you checked your battery yet to see if it is any good? You need a good strong 12 volts to power a lot of the functions in the car and when it doesnt get it the lights will come on showing an error. For mine it would be ABS light, SRS light, headlights dimming, etc which is a sign that the battery was starting to go or the alternator.
There is one rule...there are no rules!
Runninrebel211 is offline
post #3 of 7 (permalink) Old 08-27-2010, 05:26 AM Thread Starter
Originally Posted by Runninrebel211 View Post
Hey John have you checked your battery yet to see if it is any good? You need a good strong 12 volts to power a lot of the functions in the car and when it doesn't get it the lights will come on showing an error. For mine it would be ABS light, SRS light, headlights dimming, etc which is a sign that the battery was starting to go or the alternator.
Thanks, the battery is in excellent condition and the alternator is charging fine. I also notice that my ABS light flickers when driving and there is a lost of acceleration too. But why does the radio not work while it is in this condition?
John
post #4 of 7 (permalink) Old 08-28-2010, 11:04 AM Thread Starter
Please! I need help with my 1994 E320, I have ASR problems. I have checked all four sensors and the connections at the throttle, my ASR light is still on and my ABS light flickers when I drive, also my radio goes out when all this is happening then come back on when I shut the engine off. Does anyone have any suggestions, please?
John
post #5 of 7 (permalink) Old 08-28-2010, 02:01 PM
Date registered: Jul 2004
Quoted: 332 Post(s)
Forums such as this are pretty much burned out on ASR problems. There's been about two million threads on the subject, which makes for good search material. Reading the fault codes or having them read would be a good next step.
deanyel is offline
post #6 of 7 (permalink) Old 08-28-2010, 02:28 PM Thread Starter
Talking
Good News! I have solved my ASR problem, it was the alternator causing the trouble. The alternator was charging too much voltage in the system (19 volts) making the computer go wacky and cutting out the radio at the same time, also giving me all kinds of fault codes. I hope this will help someone else who's having similar problems.
John
P. S. I'm GOOD!!!!
post #7 of 7 (permalink) Old 08-28-2010, 02:34 PM Thread Starter
There is never enough info or burn out on the subject of ASR or any type of problem people may have with their car because there are always different causes to a particular problem......
Have a great day!
    ASR Problems kayegold W140 S-Class 15 10-20-2007 02:39 AM
    E420 ASR Problems teddyshoe W210 E-Class 4 02-12-2007 10:22 PM
    ASR/ABS problems Simen W140 S-Class 5 01-15-2006 05:58 PM
    ASR/ABS problems Simen W140 S-Class 4 11-19-2005 12:52 PM
    ASR Problems rrballesteros W140 S-Class 3 08-02-2004 11:10 PM
