1987 560sl high idle and abs lihgt on - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-22-2010, 08:25 AM Thread Starter
Date registered: Aug 2010
Vehicle: 1987 560SL
I have two problems with my 560sl, dont know what to do and if they are related. ABS light is on and idle is about 1200 RPMs, Can not find vacum leak and idle control valve tests okay. I put 12v onto the valve and can hear it operate and the engine stalls.The voltage to the valve was .9 volts. Is that correct? What do you think.
gary919 is offline
post #2 of 4 (permalink) Old 08-23-2010, 06:44 PM
waybomb's Avatar
Date registered: Apr 2005
Vehicle: 2005 S55; 2003 ML350; 2002 C240; 1997 C280 Sport; 1991 300SL; 1986 190e 2.3 16V (2); 1968 W30 442
Quoted: 11 Post(s)
OVP fuse blown
Thanks!
Fred
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
1988 46' Cougar US1 with Triple blown 572s
http://s4.photobucket.com/albums/y145/waybomb/
Warming the Globe, 24 Cylinders at a Time
Point me to a 126 wagon in the States PLEASE!
waybomb is offline
post #3 of 4 (permalink) Old 08-23-2010, 07:02 PM Thread Starter
Vehicle: 1987 560SL
The Ovp fuse was good. I tested the relay and it does not operate, no voltage out and had voltage in and the control leads were good. Ordered a new relay today. Thank you very much for your input.
Gary
gary919 is offline
post #4 of 4 (permalink) Old 05-29-2012, 09:33 AM
Date registered: May 2012
Gary i am having the same issues with my 560. did you find a solution?
demattca is offline
    ABS Bulb is on and Idle is high Abdullah2009 W126 S,SE,SEC,SEL,SD,SDL Class 15 07-16-2011 09:04 AM
    High Idle and ABS j_bydesign W126 S,SE,SEC,SEL,SD,SDL Class 1 01-17-2010 10:28 PM
    high idle, from 1987 560sel V8 WESCOTAC General Mercedes-Benz 0 09-20-2009 10:46 AM
    1987 560SL rough idle when cold jkbaker4 R/C107 SL/SLC Class 0 04-26-2009 05:24 PM
    High idle and ABS light on??? HELP! 4shorts R/C107 SL/SLC Class 4 09-24-2008 12:27 PM
