2000 ML430 BAS ESP ABS light comes on when turn wheel to the right - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-20-2010, 07:40 AM Thread Starter
Date registered: Aug 2010
Hello all! i am new and have enjoyed the all info i have read. here is my issue: 2000 ML430 BAS ESP ABS light comes on when turn wheel to the right. I believe there were actually 2 issues but i have managed to repair all but this last one. Initially, i could also feel the ABS activating interrmittently when pressing the brake. below is THE list:
Step 1 - replace brake switch - no change
2. - check tire pressure and size - good
3. - test battery with it started or not with a voltmeter - 12.4v & 13.8v-good
4. - remove battery cable for 3 minutes to reset then recalibrate - no help
5. - check transmission connector & found fluid! Cleaned it. ABS issue fixed!
Some maintenance history: all brakes were replaced about a year ago, tires new about 2 years ago, 210,000km, truck gets only about 12,000km/year.
Test drove & lights went out. Turned wheel all the way to the left & no problem. Turned wheel all the way to the right and the lights came on again. If I drive for a bit & shut off vehicle the lights will go out until the infamous sharp right turn.
i suspect wheel sensor or wiring?
Willowwayne is offline
    2000 ml abs bas esp lights on loss of breaking on a turn??? luvinlife W164 M-Class 2 10-27-2011 09:07 AM
    99 ml430:BAS ESP,ETS,ABS LIGHTS ON hchambi W163 M-Class 7 04-04-2010 07:21 PM
    2001 ML430 with 139k miles BAS.ESP.ETS.ABS all 4 are on hksnlper W163 M-Class 2 12-26-2009 03:31 PM
    2000 W210 BAS/ABS/ESP marcmerc W210 E50 AMG, E55 AMG 2 02-24-2008 05:01 AM
    BAS ABS ESP Light Mike2001 W210 E-Class 6 08-05-2004 07:39 AM
