duo valve full of fluid? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-18-2010, 02:22 PM Thread Starter
Date registered: Jan 2008
I have a 2002 Clk320 with air conditioning problems. I opened the duo valve to clean it and it was full of anitfreeze and running all over the place. Is the valve supposed to be like that or do I have a leaky valve. Seams strange to me that it's filled with fluid.
susansez2luv is offline
post #2 of 4 (permalink) Old 08-19-2010, 06:33 AM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 152 Post(s)
Caveat: I have a 1988 with a monovalve. Assuming the duovalve function is similar, it must be bathed in coolant to do it's job monitoring engine coolant temperature and controlling flow through the heater core.
In other words, normal condition.
rocky raccoon is offline
post #3 of 4 (permalink) Old 08-19-2010, 07:46 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 343 Post(s)
Just fyi - the duovalve is not really part of the a/c system. It is part of the coolant system that heats the heat exchanger under control of the a/c system. It will always be full of coolant.
See the coolant circuit for your W208 below. (item 6 is shown but not referenced on the drawing)
keyhole is offline
post #4 of 4 (permalink) Old 08-19-2010, 01:38 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
The default stage for a duo-valve is open therefore coolant would flow thru it, it is closed by electrical input from the HVAC controller.
Peter Guenther is offline
    duo valve full of antifreeze? susansez2luv C208/A208 CLK-Class 6 08-19-2010 07:10 PM
    Duo valve filled with radiator fluid? susansez2luv Test 0 08-18-2010 01:14 PM
    duo-valve ? jrbjrb W220 S-Class 1 07-30-2010 12:19 PM
    is it the Duo valve or something else?? charles.hicks W140 S-Class 7 03-01-2010 11:57 AM
    Duo Valve nicobaires W140 S-Class 6 11-26-2009 12:06 PM
