Error with Engine coolant temperature signal read by CFI control module - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-17-2010, 08:07 AM Thread Starter
Date registered: Jan 2009
Vehicle: '92 300E, ~200K miles
So my check engine light on my 92 300 E went on the other day, and I'm lucky enough (or unlucky) to have the California model with built in LED on the OBD system. I read the fault codes (3, 28, 29) which seem to indicate the following:
(3) Engine coolant temperature signal read by CFI control module
(28) Intermittent contact in engine coolant temperature sensor circuit
(29) CFI and ignition control module reading different engine coolant temperature
It sounds like a loose wire possibly, but, I'm looking for some advice before I just start diving in and mucking around without having a sense of where to start. I replaced the Engine Temp Sensor (attached to the block of the engine near the back wall of the engine compartment) about a year ago, without issue. Any thoughts?
Thanks in advance.
WolfeFin is offline
    Seats ESA control module signal to CAN bus questions 000-668 W210 E-Class 1 08-17-2010 09:22 AM
    Code 11, Tn-signal (rpm signal ) at engine control module faulty ocampg W124 E,CE,D,TD Class 2 06-11-2010 07:23 AM
    Engine coolant temperature sensor D4LJE W124 E,CE,D,TD Class 2 03-29-2010 10:41 AM
    Engine Coolant Temperature Circuit Malfunction xhino87 W140 S-Class 6 01-15-2010 03:53 AM
    Error Signal (Yellow Engine) pdiddy26 W211 E-Class 1 02-29-2008 04:32 AM
