ML320 Slips out of gear into neutral - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-16-2010, 07:09 AM Thread Starter
Date registered: Aug 2010
Smile ML320 Slips out of gear into neutral
My ML320 has slipped out of drive gear and into neutral while driving up a very gentle slope/hill. I accelerate, the tac reves but there is no power, just like when you are in neutral gear. This has actually happened three times in the last five years on the same exact street, almost at the same exact spot. Its very uncanny, my ML320 has never slipped out of gear anywhere else, just this same street in same area of street. I pull over and put vehicle into park and then back into drive and vehicle resumes with no problem. Anyone have any ideas?
MISSMARVELOUS is offline
post #2 of 4 (permalink) Old 08-16-2010, 07:19 AM
eric242340's Avatar
Quoted: 283 Post(s)
Have you checked the transmission fluid level and quality? also how many Km has the car done? Has the transmission fluid and filter ever been changed?
eric242340 is offline
post #3 of 4 (permalink) Old 08-18-2010, 01:35 PM
had the same problem on my s320.. had to rebuild the transmission.. you can change the fluid and filter but that wont help..clutches are worn out
AldinS is offline
post #4 of 4 (permalink) Old 08-20-2010, 07:16 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 343 Post(s)
Three times in 5 years - in the same place. That's spooky.
I wouldn't go there any more. if I were you....
keyhole is offline
    Tranny Slips in 2nd gear surem03 W210 E-Class 5 03-12-2010 07:01 PM
    Transmission slips into Neutral on slow downs Bear2000 W126 S,SE,SEC,SEL,SD,SDL Class 2 11-30-2008 06:09 PM
    Rough Idle in gear and neutral jlougster W210 E-Class 6 06-27-2007 09:54 AM
    Coasting in Neutral Gear? MBSLRwannaBE R171 SLK-Class 37 05-26-2007 12:45 AM
    Transmission slips and jumps out of gear when hot... Tranny svc. done - any ideas for fix? GermanCarNut W124 E,CE,D,TD Class 2 06-06-2005 07:55 PM
