Drilled Rotors or Not? - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 08-15-2010, 07:30 AM Thread Starter
Date registered: Aug 2010
Vehicle: 1983 380sl, 2006 Porsche CaymanS, 2012 ML350 Blutec
When I hit my brakes hard the car pulls to the left, right, left, etc.
So I am told that I need brakes and wonder if any of you have tried the drilled rotors?
I see these on eBAy and wonder if they would be right for my 83, 380sl
Thanks,
Tim
Archer993 is offline
post #2 of 19 (permalink) Old 08-16-2010, 12:06 PM
waybomb's Avatar
Date registered: Apr 2005
Vehicle: 2005 S55; 2003 ML350; 2002 C240; 1997 C280 Sport; 1991 300SL; 1986 190e 2.3 16V (2); 1968 W30 442
Quoted: 9 Post(s)
No, they won't help your issue, and you don't need drilled rotors.
When was the last time you changed your barkle fluid? Maybe it's time to do a complete brake job - including rebuilding the calipers and replacing the brake fluid. I'd go with OEM everything.
Thanks!
Fred
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
1988 46' Cougar US1 with Triple blown 572s
http://s4.photobucket.com/albums/y145/waybomb/
Warming the Globe, 24 Cylinders at a Time
Point me to a 126 wagon in the States PLEASE!
waybomb is offline
post #3 of 19 (permalink) Old 08-16-2010, 01:30 PM Thread Starter
Had the fluid flushed just last week - pulled the day before the flush and the day after.
Just thought the drilled rotors would help with fade, after this pull problem is solved.
post #4 of 19 (permalink) Old 08-16-2010, 07:18 PM
waybomb's Avatar
Quoted: 9 Post(s)
I think you'll find that when your brake system is as-new, they will be fine.
Thanks!
Fred
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
waybomb is offline
post #5 of 19 (permalink) Old 08-16-2010, 07:36 PM
~BANNED~
Date registered: Mar 2009
Vehicle: 2006 E320 CDI
You may need ball joints. When you had them replaced?
isstay is offline
post #6 of 19 (permalink) Old 08-16-2010, 08:44 PM
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Quoted: 2 Post(s)
If the car is pulling during breaking, you need to look at the calipers, not the rotors. Take the car out for a drive and take the temperature of the wheels with an infrared thermometer. If one wheel is much hotter than the other, you've found your offending caliper.
If not, take a look at the rubber brake lines. If they are as old as the car or over 10 years old, replace them. It's probable that an old line has collapsed inside and is acting as a check valve, not letting fluid out of the caliper.
If the brake lines and calipers check out fine and you still have the pull, then it's time to check out the front end components.
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline
post #7 of 19 (permalink) Old 08-17-2010, 04:07 AM Thread Starter
Thanks very much for the advice. I DO have that kind of thermometer. I'll do the test later this week. I am sure the brake lines are 27 years old so there could even be a combination of factors...
post #8 of 19 (permalink) Old 08-19-2010, 07:34 PM Thread Starter
The back right wheel (that I have heard squeal a little in the last week) was running 15-20 degrees hotter than the back left.
Might that be the culprit? Caliper issues?
Thanks
post #9 of 19 (permalink) Old 08-19-2010, 08:08 PM
Kajtek1's Avatar
Quoted: 1167 Post(s)
15 -20 degrees is too small difference to draw any conclusion. Could be sunny side v/s shade.
I think lot of people are buying drilled rotors for the looks. That is just like air fresheners or CD discs hanging from rear view mirror.
Kajtek1 is offline
post #10 of 19 (permalink) Old 08-19-2010, 08:31 PM Thread Starter
Another test is in order.
I had pulled into the garage and there was a 10 minute lag-time for cooling.
I have had drilled rotors on Porsches for years without rust.
IMHO drilled might not really belong on this model-aesthetically anyway.
    Brake Rotors - C32, C55, SLK55 - OEM Cross Drilled rotors - Brand new - $200 shipped phate For Sale/Wanted/Trade/Giveaway 11 09-01-2010 04:18 PM
    F.S:BNIB cross-drilled/slotted F+R rotors S-class/CL rotors slaughterhouse For Sale/Wanted/Trade/Giveaway 5 01-15-2010 08:03 PM
    X Drilled Rotors WaveyKat W203 C-Class 4 03-21-2005 05:56 PM
    Drilled ROTORS WaveyKat W203 C-Class 4 01-24-2005 09:09 AM
    X-DRILLED ROTORS CaliE320 W124 E,CE,D,TD Class 18 08-30-2004 04:28 AM
