Changing Low beam headlamp 2005 C-230 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-14-2010, 09:25 PM Thread Starter
Date registered: Dec 2008
Post Changing Low beam headlamp 2005 C-230
This is very simple It took us awhile to figure this out with all the posts so maybe we can simplify it for those who need it simple.
1) Press the clamp housing cover tab. Located at the top and slightly to the right looking straight down on it. It will pop off.
2) Pull the electrical connector off the bulb, you may have to wiggle it a little but it will pull straight off. Might take some muscle it will pop off.
3) The h7-55w 12v lamp will be right there. There are two tabs that stick out located on both sides of a ring looking down on it. These tabs are on a round plastic ring around the outside of the bulb that will swivel around the bulb. With your right hand place your fingers on both and rotate counter-clockwise, it will produce one poping sound. Now take out the old bulb.
4) Take the new bulb and replace with the large tab on the bulb pointing upward. Now just place your fingers on the round plastic ring tabs and rotate it clockwise until you feel it move back into place and hear it pop. Your all set to place the electrical connector back on.
5) Now just take the housing cover with two small tabs on the bottom, align in the holes and snap back on where the push tab botton goes back near the top.
Your Done. Once you do this it should only take you three minutes to install. First time maybe ten.
daviddolve is offline
    low beam out high beam works caution W163 M-Class 9 03-22-2013 03:05 AM
    Low Beam or High Beam WITHOUT Parking Lights Sandra_Dee C215 CL-Class 3 11-30-2009 03:48 PM
    Low headlight beam on a 2005 E-500 wittgenstein83 W211 E-Class 0 08-28-2009 08:50 PM
    Changing Oil in 2005 C-230 Sport gisham W203 C-Class 1 10-27-2006 02:06 PM
    Lighting up the night! Snow + low beam/high beam Bi-Xenons & foglamp pics! Drew W163 M-Class 7 03-11-2003 11:37 AM
