2003 C240 4matic troubles update - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-08-2010, 06:24 PM Thread Starter
Date registered: Jul 2010
Vehicle: 2003 C240 4matic
Question 2003 C240 4matic troubles update
My 03 C240 had a sudden rough idle issue with puffs of smoke out the exhaust. OBDII indicated misfire cylinder 1,2&3 and a multiple misfire code as well.
I changed the plugs, wires and all coil packs, air filters, oil and coolant. I cleared all the codes and the car was running better that ever.
Now two weeks later my wife is driving the car to her moms house (180 miles) and the CEL comes on and the same issue is back whith the smoke and all. When the care is shut down and restartd the smoke clears and runs fine. Her dad hooked the car up to a OBDII reader and P0301 misfire on cylinder #1 one. So he replaced all the plugs again and the car was running fine.
Now on her way back home the same thing again. I am thinking MAF or crank position sensor. I need some help or suggestions
Jim9514 is offline
    2003 C240 4matic Troubles Jim9514 General Mercedes-Benz 0 07-15-2010 07:53 PM
    2003 c240 4matic useing coolant contact148 W203 C-Class 0 12-08-2009 05:14 PM
    2003 C240 4matic question RDM3 W203 C-Class 0 09-14-2009 07:06 PM
    What kind of brake fluids does my 2003 c240 4matic need? dg45 W203 C-Class 1 08-14-2009 12:36 AM
    Just purchased a 2003 C240 4Matic with 30k miles. silvershark W203 C-Class 9 10-18-2007 10:49 AM
