2000 C230 dash display - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-05-2010, 01:28 PM Thread Starter
wantentoo's Avatar
Date registered: Aug 2010
Vehicle: 2000 C230
Send a message via Yahoo to wantentoo
I have a 2000 C230 that the dash digital/lcd display changes. Sometimes the digits are there and then sometimes they are partially there. Is this something that I as an owner can fix or is this a shop service item.
wantentoo is offline
post #2 of 3 (permalink) Old 08-30-2010, 01:01 PM
Date registered: Nov 2007
Vehicle: C230 W203 2003
Post C230 Dash Display Light
Hi I too have the same issue I have A C230 2003 and I have seen it getting worst now it is hard to read the dash display. Where you able to find out how to fix the issue?
I found this information you may want to try this if it helps Im going to try it this weekend:
Replacing the DASH DISPLAY LIGHTS
If the display darkens (background *and* numerals), it could be the
backlight(s) for the LCD display. LCDs are variable filters which must be
illuminated from behind to actually display anything. The lamps used are
typically like the 1.5 watt bulb seen at the bottom of this page (Osram bulb
with beige plastic base $1.58 each, as what my CLK uses):
If they are the culprit, they are accessed from the backside of the
instrument panel. I meant to take and post some pics and details of my CLK's
instrument cluster when I had it out, but have not had time (sorry).
Basically, if the steering wheel can be moved down or extended, do so... the
extra clearance makes it easier to work on the panel. Next, two hooked
removal tools (available from Mercedes or can be made from stiff wire) are
inserted between the dash padding and the cluster, one each at the ten
o'clock and two o'clock positions, they are then rotated, and the instrument
cluster can be pulled out:
http://www.designtech-intl.com/Conte...04/note159.pdf
You may have two electrical cables on the back... one on each side. When the
instrument cluster is out enough to gain access, slip the (gray?) retainer
down and pivot out the connector, do the same for the other side and the
dash will come right out. You'll see a bunch of lamps on the back side.
Replace the ones that are behind the problem display. Of course it may just
be a loose connector (less likely, IMO), but the cluster would also have had
to been removed to reseat them.
Reassembly is a snap. Put the cluster back near the opening, re-insert the
cables and pop their retainers back up, then push the cluster back into the
opening... voila... finis!
Sounds tough, but the whole shebang can be done in well under an hour the
first time through it... if you ever need to do it again for other lamps,
you'll be able to do it in fifteen minutes or less (hey, you're a pro now!)
DISCLAIMERS:
THIS MAY *NOT* BE THE ROOT OF YOUR PROBLEM!!!
Rumbero is offline
post #3 of 3 (permalink) Old 08-30-2010, 03:43 PM
Musikmann's Avatar
Quoted: 6 Post(s)
In addition to the scholarly and well written advice above, try a search for pixels or "missing pixels". I guarantee you can read about those all night. If those are your issue, there are shops who can fix it and a few DIY threads where members seem to have fixed their own.
Musikmann is offline
2000 c230 kompressor interior dash trim!?! decompoze W202 C-Class 5 10-20-2011 01:27 PM
2000 C230 Dash C230_Sport_Kompressor Audio & Telematics Forum 0 06-09-2008 08:41 PM
Dash display NukeSLK R171 SLK-Class 5 01-18-2007 02:54 AM
C230 Dash display Tom Haenisch W202 C-Class 2 12-22-2006 07:25 AM
Dash Temperature Display BOB703 W124 E,CE,D,TD Class 11 08-23-2006 09:42 PM
