SL water leaks - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-03-2010, 01:16 PM Thread Starter
Date registered: Aug 2010
Vehicle: 1975 450SL / 2004 E430
SL water leaks
Hi folks,
On a 1975 SL, when you run water down the vent grills at the cowl, it ends up on the floor. It appears to be coming out of the lower heat AC housing. The left and right condensor drain tubes are clear and intact. When the air is on, the condensation water runs out of the tubes. Are ther any other drain tubes or holes from the air intake grills? If so, where do they exit the car? I have owned this car for over 25 years and have had a water problem for a long time, but am just now starting to hunt it down.
Thanks for the help
edg is offline
post #2 of 2 (permalink) Old 08-15-2010, 04:15 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
    Water leaks gregdeklerk W126 S,SE,SEC,SEL,SD,SDL Class 1 09-29-2006 06:57 AM
    Water Leaks BathSLK R171 SLK-Class 12 06-18-2005 09:31 AM
    water leaks 90300sl5spd R129 SL-Class 3 12-03-2004 04:15 PM
    Water leaks Doug Dees G-Class 5 07-29-2002 09:23 AM
    Water Leaks Richard Dawson-Gerra G-Class 2 02-27-2002 03:19 PM
