smoking 380SL help - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-01-2010, 01:02 PM Thread Starter
Date registered: Aug 2006
Vehicle: 1981 380 SL
Unhappy smoking 380SL help
380SL 1981 light and heavy blue smoke drifting out of the exhaust, did compression check, dry and wet and it was well within specs, changed all valve seals which did nothing, changed transmission modulator, still no change. Eng starts and runs good, 110,000 mi. any ideas what to check next? HELP!
The dipstick looks really new, i suspect it has been replaced with the wrong length one, it measures 22 1/2 from tip to tip. Or 21" from the lower tip to the dip stick tube cap. can anyone measure their dip stick and let me know if its the correct length please??
If it was too long this would explain why the engine is puffing, too much oil in the crankcase.
dwksik is offline
    Smoking: Why? DP Off-Topic 66 09-25-2009 09:07 AM
    smoking ml lt@sanrspain.com General AMG 7 04-09-2009 02:06 AM
    Still Smoking... Gregs300CD W123 E,CE,D,CD,TD,TE Class 8 09-23-2006 03:33 PM
    Smoking Nehdad R129 SL-Class 3 08-03-2003 06:37 AM
    Smoking Big D W126 S,SE,SEC,SEL,SD,SDL Class 3 07-24-2003 08:54 PM
