Transmission issue? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-31-2010, 03:18 PM Thread Starter
Date registered: Jul 2010
Unhappy Transmission issue?
Hi,
I have an automatic '85 190E. For a few weeks whenever I started the car, and had it in Park/Neutral the engine would rev and the rpm meter would shoot up until I shifted gears. Then it would jerk and slow down.
Then yesterday as I was trying to leave I put the car in reverse and it started going forward. The same happened for Neutral, Drive, 3 and 2.
So I turned off the engine and put it in Neutral so I could push it back to go forward. When I was actually able to get it moving I pressed the gas and the rpm went up, but the car wouldn't go above 20 (at best).
I checked the Tran fluid and it was fine. A friend said it may be a sensor.
Anybody have any ideas?
archiefan is offline
    Transmission issue? b-bus W123 E,CE,D,CD,TD,TE Class 6 03-29-2010 10:49 AM
    transmission issue mpml350 W163 M-Class 15 07-15-2009 08:48 AM
    Transmission Issue wvcaudill W163 M-Class 31 04-20-2009 05:46 AM
    Transmission ISSUE Southern500 W124 E,CE,D,TD Class 8 09-26-2007 07:12 PM
    Transmission Issue bobbobruns12 R/C107 SL/SLC Class 2 09-23-2004 11:51 AM
