No start, glowplug relay buzzing - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-31-2010, 09:27 AM Thread Starter
Danimal's Avatar
Date registered: Nov 2005
Vehicle: 1985 300TD Calif
Post No start, glowplug relay buzzing
Yesterday after changing oil, oil filter, and fuel filter, my 1985 TD wagon would not start. When the ignition was turned on, a loud buzzing noise emanated from the glow plug relay box. The starter would not engage when twisting the key. This seemed to me to be totally unrelated to the maintenance I performed. There seems to be enough fuel in the system to not be an issue. I see no faulty connections. I charged the battery overnight with a 10amp charger; no change in the issue this morning.
Do I need a new (or junk yard) glow plug relay box?
My thanks to all you avid benz trouble shooters for issues I was able to solve from previous posts. The only thing I found on this issue ended up being a undercharged battery.
Danimal is offline
    Inside glowplug relay with pictures Olivier A W210 E-Class 4 04-16-2012 10:36 AM
    location of glowplug relay-316 sprinter tibsy W901-905 Sprinter 2 09-28-2010 08:24 AM
    Battery goes flat when glowplug relay is connected conair4u General Mercedes-Benz 1 03-19-2010 10:26 AM
    Glowplug Relay - Prevent Car from Cranking? clowe92656 W123 E,CE,D,CD,TD,TE Class 3 06-16-2008 03:29 PM
    Fast Glowplug Relay Kit- '78 240D christophesteele W123 E,CE,D,CD,TD,TE Class 5 06-04-2008 12:25 AM
