1998 sl500 help - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-31-2010, 10:25 AM Thread Starter
Date registered: Jul 2010
Vehicle: 1998 sl500
1998 sl500 help
Hello new to this forum. From Pennsylvania. 1998 sl500, 163,000 miles. Runs, operates,and sounds perfect. Recent issue as follows:
1998 SL500. 163,000 miles. Check Engine Light Comes on. 30-50 miles later, while driving, blinking gas guage. This blinking gas guage can be reset by restarting engine. Took to mechanic. Received back verbatim "Pull codes and check out car. Car had a large evaporator leak which was purge valve line disconnected. RE: attached line and replaced bad air mass meter and air filter set". $800.00
12 hours and 60 miles later, check engine lights up again. Took back. Mechanic changed seal for gas cap and replaced a hose. $70.00. 65 miles later, check engine light is on -- 30 miles later, blinking gas guage. All Guages are all registering perfectly, car runs and sounds perfect.
One response suggested I get actual codes from mechanic and then pose question. Any insight would be greatly appreciated.
enpase is offline
post #2 of 3 (permalink) Old 07-31-2010, 10:54 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Sounds like you're now past what it would have cost to have it fixed the first time at a Mercedes dealer.
Saving $$ is heck.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 08-01-2010, 11:12 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
    FS: 1998 SL500 1998 White 20K miles in LA, CA always covered PERRYinLA For Sale/Wanted/Trade/Giveaway 1 01-05-2012 05:50 PM
    Will 1998 SL500 instument cluster work in 1997 SL500 cigator R129 SL-Class 6 01-29-2010 08:32 PM
    1998 SL500, I think? Mikenuts76 R129 SL-Class 6 06-11-2009 10:08 PM
    New to me 1998 SL500 tizfun General Mercedes-Benz 0 08-04-2008 07:37 PM
    my 1998 sl500 tennis1 R129 SL-Class 5 06-07-2006 10:49 AM
