Hello Benz owners! Please help. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-29-2010, 11:26 PM Thread Starter
Date registered: Jul 2010
I have 1998 e320, it would stall and after waiting for few minutes it'll start but after going for few blocks it would stall again. No check engine light would come on. Replaced crankshaft position sensor after reading this forum. Still doing the same thing. Today it got worse, it only started after waiting for couple of hours. Not getting any voltage at the fuel pump when trying to start it (fuel pump fuse is OK). Something is preventing power from going to fuel pump ocasionally.
Dima89 is offline
post #2 of 4 (permalink) Old 08-01-2010, 11:39 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
post #3 of 4 (permalink) Old 10-30-2010, 03:07 PM Thread Starter
It was just a fuel pump relay located inside fuse box under rear seat. Radio shack price is around $7. Just need to trim plastic sticking out. To find a problem, I pulled out relay, took cover off, put relay back and pushed contact with a finger (don't worry its only 12 volts, you will not get shocked), I heard fuel pump going, at the same time I reached for the key and tried to start a car, it started right away. As soon as I let go the relay, engine stalled. It has been few months now, engine never stalls. Replacing crankshaft position sensor was waist of money.
Dima89 is offline
post #4 of 4 (permalink) Old 10-30-2010, 05:05 PM
leapyfish's Avatar
Quoted: 4 Post(s)
    New used benz owners in Arizona pjmoraldo General Mercedes-Benz 2 05-03-2010 07:14 AM
    Hello Benz Owners OleChunky General Mercedes-Benz 1 02-22-2009 08:33 PM
    detroit benz owners RickASolis W126 S,SE,SEC,SEL,SD,SDL Class 1 01-13-2009 05:35 AM
    What DO Benz owners want? Check Codes W210 E-Class 9 05-22-2008 02:09 PM
    For all you black Benz owners vinny70 W203 C-Class 6 05-17-2004 07:32 AM
