C220 key broke in ingition lock - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-29-2010, 06:51 AM Thread Starter
Date registered: Nov 2009
Vehicle: 1994 and 1995 C220 and a 2000 ML320
Question C220 key broke in ingition lock
I have read the threads on other mercedes lock removel and was wondering if someone new the best way to remove the lock out of a 1995 C220 with the key broken off in the lock. I have not been able to remove the key it is to deep in the lock. I have the bottom half of the dash removed the instrument cluster loose and ready to be pulled out as soon as I pull the steering wheel off. W202
Redmanrh is offline
post #2 of 9 (permalink) Old 07-29-2010, 11:04 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 385 Post(s)
W202?, W203?, W204?.
We are not mind-readers here. Provide all details.
keyhole is offline
post #3 of 9 (permalink) Old 07-29-2010, 11:06 AM Thread Starter
Sorry new to mercedes w202
Redmanrh is offline
post #4 of 9 (permalink) Old 07-30-2010, 02:21 AM
keyhole's Avatar
Quoted: 385 Post(s)
That's not 'all details'......what is difficult about providing year, location. etc, like everybody else here?
However, about your EIS (electronic ignition switch module. N73)
1. It's almost impossible for the fob key to break off inside the module. How did you manage to do that?
2. You need a special M-B tool (or maybe fabricate one yourself) to remove the unit. If you study the unit, you will see 4 castellated shoulders for the special key to grip, before it is turned. If you try to remove it with ordinary tools you will probably wreck it completely.....
keyhole is offline
post #5 of 9 (permalink) Old 07-30-2010, 12:51 PM Thread Starter
Red face
The 1995 c220 is my son's car, he broke off the key in the trunk lock, he was able to get the key out of the trunk lock, then he super glued the key togeather and stuck it into the ignition and rest is history.
I have both styles of removel tool and that part is done.
I read on the WWW. were someone had ground down the lock pin. So I'm at the point were I can drop the steering column and grind the pin.
Redmanrh is offline
post #6 of 9 (permalink) Old 07-30-2010, 01:04 PM
Tri-Star's Avatar
Date registered: Aug 2007
Vehicle: C320 4matic
Originally Posted by Redmanrh View Post
He was able to get the key out of the trunk lock, then he super glued the key togeather and stuck it into the ignition and rest is history.
Never heard that one before! Sorry I can't help but good luck with everything.
Tri-Star is offline
post #7 of 9 (permalink) Old 07-30-2010, 04:32 PM
keyhole's Avatar
Quoted: 385 Post(s)
OK - I'll admit I'm baffled. I was not aware that the fob key could be used in the trunk. Maybe on the C220 it can.
However, my understanding is that normally the key is held 'locked' in the EIS module only when the shift stick is in D, N, and R by a locking valve/locking cam. In P, and when the key is in pos 0, the shift lock is released. There is a cable that provides mechanical linkage between the ignition switch module and the gear shift that ensures this operation.
Is the key now in pos 0, with the gear stick in P?
Failing that, as the key is now toast, can you drill into the stuck part, and fit a self-tapped screw in there? I think that the end is held in place by light spring pressure, and if it is not actually locked, you might be able to pull it clear.
keyhole is offline
post #8 of 9 (permalink) Old 08-01-2010, 01:37 AM Thread Starter
Lightbulb
Yes, it is in O position and in park. When I tried to drill out the tumbler all I did was brake a couple of drill bits an didn't even scratch the lock plate.
Thanks for the reply, So I was able to lower the steering column down were I could grind the lock pin flush to the lock housing, which allowed me to slide the lock housing off of the steering column. With lock housing in hand, I still could not get the key out or get the tumbler to turn. So I split the the tumbler cover and still could not get the key out or the tumbler to turn. I will be getting a new lock housing, tumbler, keys, ignition switch and a warning switch. Then comes the fun part of putting it back together and hope it all works.
Redmanrh is offline
post #9 of 9 (permalink) Old 03-23-2012, 09:43 PM Thread Starter
2012 Ignition switch still working, just had car painted, 210000 miles and still running strong, working on a surge and stall problem now.
Redmanrh is offline
    Key in ingition buzzer replacement recommendation? Scoot Vintage Mercedes-Benz 0 08-17-2009 10:47 AM
    Broke Key Z32TT R129 SL-Class 11 01-12-2009 07:38 PM
    300SD door lock issue (can't lock with key, but can unlock) Mugsy90/10 W126 S,SE,SEC,SEL,SD,SDL Class 5 11-12-2006 06:12 PM
    Help! The key broke! tempoct R170 SLK-Class 15 12-23-2004 08:13 AM
    300SD Lock Problem: CANT LOCK TRUNK WITH KEY?? regsatx W126 S,SE,SEC,SEL,SD,SDL Class 1 11-27-2004 08:57 PM
