1999 E430 Sport Front Brake Pad Change - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-25-2010, 04:47 PM Thread Starter
Date registered: Nov 2009
I'm changing the brake pads for the first time on this car, and I'm having difficulty removing the caliper. It seem like the tension on the brake line is holding it on. Do I have to remove the brake line to get the caliper off? I've changed brakes on many other cars (but not a MB) and never had this problem.
Thanks!
E430Lover is offline
post #2 of 9 (permalink) Old 07-25-2010, 07:36 PM Thread Starter
Never mind, I got it, it was just being stubborn!
post #3 of 9 (permalink) Old 07-27-2010, 12:23 PM
waybomb's Avatar
Date registered: Apr 2005
Vehicle: 2005 S55; 2003 ML350; 2002 C240; 1997 C280 Sport; 1991 300SL; 1986 190e 2.3 16V (2); 1968 W30 442
Quoted: 8 Post(s)
If all you are doing is changing the pads, then why are you taking the caliper off?
Thanks!
Fred
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
1988 46' Cougar US1 with Triple blown 572s
http://s4.photobucket.com/albums/y145/waybomb/
Warming the Globe, 24 Cylinders at a Time
Point me to a 126 wagon in the States PLEASE!
waybomb is offline
post #4 of 9 (permalink) Old 07-27-2010, 04:27 PM Thread Starter
I'm done now, but how would you press the piston back in without taking off the caliper?
George
post #5 of 9 (permalink) Old 07-27-2010, 04:56 PM
waybomb's Avatar
Quoted: 8 Post(s)
take a heavy flat blade screwdriver or prybar and pry the old pads back outwards toward the caliper. Once you get one done, do the other. You may have to use two screwdrivers so the other side doesn't move back out. Pull the pins, slide the old pads out, slide the new ones in, put the pins in.
Thanks!
Fred
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
waybomb is offline
post #6 of 9 (permalink) Old 04-15-2011, 03:01 PM
Date registered: Dec 2010
Vehicle: 2000 E430
Sounds like a smooth operation. S one would have to accept that it isn't in real life. I don't care how nice these cars are, engineers are involved in the designing. Jusy joking.
Is there a pic showing this any where on the site? If there is, I haven't happened by it.
Thanks,
Doug
doug999 is offline
post #7 of 9 (permalink) Old 04-15-2011, 07:03 PM Thread Starter
It's been awhile now, but from what I remember it was no different from the Toyotas, Nissans, and Hondas that I've done. I was just a little nervous, MB can sometimes be a little different. I still prefer to remove the caliper, it is generally only two bolts (undo one and loosen the other to pivot, or just remove both. It decreases the chances of scratching the rotor when you push the pistons back in, and also some pistons push in easier when you press on the center rather than one edge, which is what would happen if you use a screwdriver. I helped a buddy with his Honda a couple of weeks ago and even using a c-clamp it was really being stubborn until I centered it in the piston, then it went in like butter. Also, need to check the bolts for grease if its a floating caliper. Didn't used to do that, then one time a bolt got corroded and stuck and the caliper wouldn't float, ending up eating a pad. Don't remember if the E430 is floating or not, though!
post #8 of 9 (permalink) Old 04-19-2011, 05:46 PM
Vehicle: 2000 E430
Okay...I'll bite: What do the pins look like? All I see are some spring clips or something that appears to be springs. There also isn't much room to wedge a flat screwdriver, or much of anything else, in there... (and I thought my 98 Lincoln connie was wierd)
Doug
doug999 is offline
post #9 of 9 (permalink) Old 04-19-2011, 08:02 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If you ever get tired of playing in the general forum, head on down to the W210 forum, where you will find a wealth of information about your car, including pictorial DIYs.
Check Codes is offline
    FS - NEW 1998 E430 Sport Front Brake Pad Set Ericeclass For Sale/Wanted/Trade/Giveaway 0 04-05-2010 07:54 PM
    MY DIY Benz Front Brake Pad Change 9pm jason619sd W203 C-Class 5 03-15-2010 02:26 PM
    Front brake pad problem on 1999 racwld1 R129 SL-Class 20 07-23-2009 08:02 PM
    Repair bolts for front end alignment on 1999 E430 Sport? RSIESQ The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 03-06-2005 09:46 AM
    It is time to change front brake pad... chanm W163 M-Class 21 05-20-2003 04:57 PM
