C220 Coupe - how do I remove flast badge and fit stra badge to my 2006 coupe C220? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-24-2010, 03:31 PM Thread Starter
Date registered: Jul 2010
Red face C220 Coupe - how do I remove flast badge and fit stra badge to my 2006 coupe C220?
says it all - how do I remove flat badge and fit a star badge from a same year (2006) UK C180 to my coupe? Secondly, why did Mercedes not fit the star badge as standard to my model? Cheers Nige Moore
Last edited by baggienigel; 07-24-2010 at 03:40 PM. Reason: slipped up in spelling on title
baggienigel is offline
post #2 of 4 (permalink) Old 07-24-2010, 03:50 PM
millpond's Avatar
Date registered: May 2010
Vehicle: 2007 SL 550, 50th Anniversary Edition
Not sure about your specific badge, but a lot of them are held on with an adhesive. If it is, heat it with a hairdryer, then pry off with your fingers. It may also help to use a sawing motion underneath the badge with monofilament fishing line or dental floss. New badging usually comes with an adhesive backing for easy installation.
millpond is offline
post #3 of 4 (permalink) Old 07-26-2010, 10:24 AM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
If I remember rightly your car has a star in the center of the grille, making the stand up star redundant. This used to be common practice for MB, stars on hood for sedans and star in grille for coupes, tho that has changed in the last couple of years.
Your flat badge should simply unscrew from the bottom and a stand up star is the easiest modification you will ever do to a Benz, just twist the tab on the bottom 90-degrees and it locks, you can practice with it first before installing. The stand up star is cheap and readily available. Personally I'd switch the grille to an aftermarket one with slats only if you're adding the hood star but it's all up to your personal preference.
The Coupe Group on Facebook
DirectLA is offline
post #4 of 4 (permalink) Old 07-26-2010, 10:52 AM Thread Starter
Thumbs up Re C220 hood/bonnet badge removal
Guys - thanks for your replies. Had a good look yesterday, my badge looks to be riveted in place by 2 rivets. Looked at my dads C240 with bonnet star, but my badge is much bigger than the base of his star, so don't know. Also the access hole on mine is much smaller as it seems to have a double skin.....
Also, forgot to mention my car is an unbadged 220 CDi Coupe AMG, even listed on DVLA as AMG. not sure if it was just wheels/skirt/body bits and grille, black mesh mouth and black mesh fog surrounds added at factory or if it really is an AMG model......I'm sure there are more expert opinions, but all I can say is, at 50, its my first Merc - and I love it! The most comfortable and pleasureable easy car to drive. I'm hooked, will never buy anything else. It's my Dad's fault for buying a C240 V6 last year, and he's 76!
    High mileage badge placement on coupe: WHERE should it go? cascade W126 S,SE,SEC,SEL,SD,SDL Class 31 09-07-2011 09:58 PM
    merc c220 coupe radioman789 General Mercedes-Benz 1 02-08-2010 09:24 AM
    New memberwith C220 CDi Coupe Smiffy97 General Mercedes-Benz 2 07-08-2009 10:35 AM
    c230 coupe flat hood badge Jrida47 W203 C-Class 4 10-16-2006 11:37 AM
    OT: Saw a C coupe today, with a C32 and AMG badge on rear, POSER ? LelloSLK R170 SLK-Class 9 07-30-2003 05:38 PM
