2002 s500 codes on dash - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-21-2010, 05:58 PM Thread Starter
Date registered: Jun 2009
02 s500
the dash keeps saying to check my left low beam.( what does this mean?)
does it mean the bulb is "about" to go out? it seems to work fine.
also it says brake line wear (what does this mean?) 4 months ago i replaced my rims with new stock ones due to cracking my pass side rear rim in half.
tried to hook my obd-2 to it and it said failed to connect, make sure car iginition is on. it was and was connected properly.
please help thanks
wizzy214 is offline
post #2 of 3 (permalink) Old 07-22-2010, 10:05 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
It means the system thinks the bulb is burned out. If it's not, it's a system problem but it's pretty easy to put in a new bulb to see if that helps.
It's brake LINING wear, which means car needs new brake pads.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 07-22-2010, 01:38 PM Thread Starter
thanks for the quik responce
what part number are the low beam bulbs 9004?
wizzy214 is offline
    2000 s500 Misfire Codes gahmed W220 S-Class 9 06-15-2012 04:35 PM
    how to display codes on dash? kidkar R170 SLK-Class 6 04-16-2009 11:45 AM
    95 S500 - Need Help with Engine Codes Eva89 W140 S-Class 1 02-03-2009 10:26 AM
    After getting my codes checked out, they say "Misfire Codes" for my s500 gahmed General Mercedes-Benz 10 07-17-2007 05:06 PM
    does anyone have the unlocking codes for w220 s500 uk chink_uk W220 S-Class 3 01-02-2007 01:48 PM
