Intermittent Air conditioning (and heat) blower - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-21-2010, 05:02 PM Thread Starter
Date registered: Aug 2008
'88 300SEL
Previous owner replaced the...
Climate control switches (Temp wheel/buttons/Fan control)
...and problem still exists:
Today in 90-degree heat and blower on low, auto, or high and temp wheel completely in blue A/C turned itself off. Then turned back on. Then again and again sometimes with a low fan and sometimes slightly higher. Sunroof closed. Windows closed. When air blows it "usually" blows cold (I'll continue to track this)
I believe the car also did this in the winter with the heat cycling on and off. For this I purchased an INTERIOR TEMPERATURE SENSOR HEAT EXCHANGER at heater case but have not installed it as of yet.
For the A/C do you think I need...
AMBIENT AIR TEMPERATURE SENSOR on the front inner roof rail
If so can you point out the specific location of the installations?
Thank you
Smrtini is offline
    2004 E320 4-Matic Wagon - Intermittent Air Conditioning / Cooling RaketeBlaue W211 E-Class 1 05-20-2010 12:58 PM
    air conditioning blower motor??? MBENZ1987 W140 S-Class 3 07-21-2008 08:42 PM
    heat/ac blower intermittent operation W124_fan W124 E,CE,D,TD Class 2 03-11-2008 07:44 PM
    ML320 Air Conditioning- Blower OK- Air hot SatDoug W163 M-Class 6 09-16-2006 03:36 AM
    Air conditioning blower fan motor noise jruano R129 SL-Class 1 06-02-2005 05:14 PM
