cl 600 abc suspension failure - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-21-2010, 03:34 PM Thread Starter
Date registered: Jul 2010
In the passed two weeks my suspension blew 3 lines and one regulator for the r-front strut.
Could my pump be going bad and over pressurizing the system. It moans at around 2,000 rpm. But is fine at all other rpms.
the lark is offline
post #2 of 6 (permalink) Old 07-22-2010, 02:10 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 385 Post(s)
Isn't the ABC system pressure kept at the correct level by a pressure regulator system. This looks like the Pressure supply valve unit (52) and the ABC pressure sensor (B4/5).
keyhole is online now
post #3 of 6 (permalink) Old 07-23-2010, 06:42 AM Thread Starter
What does that have to do with suspension
the lark is offline
post #4 of 6 (permalink) Old 07-23-2010, 07:02 AM
eric242340's Avatar
Quoted: 306 Post(s)
It has absolutely nothing to do with suspension and I just banned him. He was advertising on many threads but no more.
As to your suspension the pumps are known to go bad but in this case I feel you got unlucky and a lot of smaller parts went wrong at the same, or almost, the same time. Wait out and see if anything else happens first.
ERIC.
eric242340 is online now
post #5 of 6 (permalink) Old 07-24-2010, 12:27 PM
Date registered: Sep 2009
This system runs at about 200bar. So I would not say that it is over pressurizing. But since you did blow some hoses which means most of the fluid leaked out the pump maybe going south also. Not sure how far you drove the car once the hoses blew but with no fluid in the pump it can be smoked with in 45 secs. Hope this helps and good luck.
toddfather is offline
post #6 of 6 (permalink) Old 07-26-2010, 12:01 PM
Date registered: Jul 2007
my line broke from the pump to valve...after it was fixed it's doing the exact same thing as yours....around 2200rpms it make a whine...let me know if you find an answer! thanks, john
housclass is offline
    ABC/PS pump leaking causing ABC suspension severe drop 2003 s600 W220 S-Class 16 07-03-2012 03:54 PM
    cl 600 alternator failure question cl600bill C215 CL-Class 1 09-11-2009 05:37 PM
    ABC failure need new pump cal1 R230 SL-Class 3 08-19-2008 05:54 AM
    ABC Failure srice R230 SL-Class 9 07-18-2008 11:37 AM
    ABC FAILURE Guest (MBNZ) R230 SL-Class 2 06-24-2002 10:11 PM
