transmission e320 2002 stationwagen - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-19-2010, 09:47 AM Thread Starter
Date registered: Jul 2010
car not working says oil leaked onto harness(wire) and damaged tcu and burnt plate in is 8 yrs old with 154,000 it worth putting $6400 per dealer to fix all this?aq friend owes me a favor can get me used transmission for 1500 and can install for $775.the wire harness can be cleaned but what can be done about tcu?is it ever fixable/ can it be cleaned?if not can u by a tcu used somewhere or does it have to be calibrated to my car only via from dealer?should i just fix burnt plate in transmission or replace whole transmission?please advise...
robert henrickson is offline
post #2 of 3 (permalink) Old 07-20-2010, 04:50 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
you should not need a whole transmission. yes the conductor plate leaks and the fluid actually sucks into the harness and into the tcu. once there is fluid in there it will never be the same. you need to replace the conductor plate (not whole valvebody), tcu and the harness should be available seperate.
saleen1276 is offline
post #3 of 3 (permalink) Old 07-21-2010, 08:50 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Another reason to service the transmission every 50,000 miles or so. Maybe the fluid is in fact good for life (don't buy it), but by servicing the transmission, one can at least get a chance to look at things like this and pick up on a problem before the transmission is toast.
'59 220S Cabriolet - for sale -
'83 240D original owner 351,500 miles - for sale -
'88 560SL 41,000 miles being parted out -
'99 E300 turbo 196,000 miles
'03 SLK320 34,500 miles
'14 Smart electric
sokoloff is offline
    will rims from a 2002 CL500 fit a 2002 E320 mhrycyna W210 E50 AMG, E55 AMG 3 01-20-2010 06:40 AM
    will rims from a 2002 CL500 fit a 2002 E320 mhrycyna C215 CL-Class 0 01-11-2010 01:21 PM
    car purchase: 2003 E320 or 2002 E320 (W210)? ProV1x W211 E-Class 3 03-21-2007 12:04 PM
    car purchase: 2003 E320 or 2002 E320 (W210)? ProV1x W210 E-Class 5 01-08-2007 02:16 PM
    2002 e320 wheels/tires NEW DESIGN FOR 2002 Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 01-25-2002 06:10 PM
