pipe at buttom of waterpump - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-18-2010, 05:47 PM Thread Starter
Date registered: May 2010
Vehicle: 1997 C280
Hi,
I've got a 1997 c280 with a 104.941 6 cyl. engine.
I recently got a leak which appeared to be coming from a pipe at the bottom of the water pump which was neither connected to anything or plugged.
Is there a stopcock that goes in there or a hose which goes there?
Thanks to anyone who can help.
ChromeBudda is offline
post #2 of 2 (permalink) Old 07-19-2010, 04:22 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 381 Post(s)
According to the WIS drawing, there should be a hose in there called the 'leak water pipe' (4a).
It is not clear, but it looks to me (from the added guide-line) that the lower end goes into the engine block.
Strange? Is this water pump designed to leak?
Name:	W202 water pump.jpg
keyhole is offline
    X-PIPE + NO MUFFLERS-STRAIGHT PIPE VIDEO!!! Kirill22 W204 C-Class 21 04-25-2011 01:01 AM
    Waterpump leaking?? ron in sc W124 E,CE,D,TD Class 5 02-21-2009 12:36 PM
    waterpump Alphasingularity W201 190-Class 10 03-22-2007 08:16 PM
    replacing waterpump Thomas J W126 S,SE,SEC,SEL,SD,SDL Class 4 01-31-2005 05:41 PM
    Waterpump on 300SL Franz R129 SL-Class 0 02-17-2004 04:39 AM
