Broken M103 camshaft rotor adapter distributor rotor bracket 1031580840 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-13-2010, 07:33 PM Thread Starter
DoktorNo's Avatar
Date registered: Jul 2006
Took my 1991 300SE in to have the u shaped seal replaced. Decided to have the shop replace just in case they might notice something important. They did. The camshaft rotor adapter a.k.a. distributor rotor bracket part number 1031580840 was cracked and about to fail. As you can see in the attached photos, just a small piece of metal was holding the pieces together and would have soon failed, separating the rotor from the camshaft.
If you pull the rotor, might want to check out this part.
ID:	319096   Click image for larger version
ID:	319097   Click image for larger version
ID:	319098   Click image for larger version
1971 300SEL 6.3
1985 280TE 5spd
1986 190E 2.3-16V
1986 300E 5spd 24hoursoflemons car.
DoktorNo is offline
    How do you take off the distributor rotor arm? V12StealthHunter W201 190-Class 6 05-20-2016 03:11 PM
    Rotor Driver Stuck in Camshaft Billiam W124 E,CE,D,TD Class 9 02-14-2009 10:09 AM
    Old Rotor vs New rotor bracket jeeze R129 SL-Class 4 12-21-2008 10:18 AM
    E420 M119 Distributor Rotor Bracket betapi W124 E,CE,D,TD Class 4 04-05-2008 10:29 AM
    Distributor rotor ssanmor W201 190-Class 0 11-25-2003 02:48 AM
