CEL After sparkplug,oil change & air filter 05-S430 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-13-2010, 08:08 AM Thread Starter
Date registered: Jun 2010
Vehicle: 2001-996-C4 & 2005-S430-4Matic & 2007 GL320 CDI 4Matic & 2008 C300 4Matic & 2012 S350 Bluetec
05-S430, 102k miles, Just changed plugs, oil & air filter - CEL light came on w/no noticeable issues. Any ideas? I am thinking possible MAF, how do I clean that? - cannot find any DIY in forums.
Wilburh1 is offline
post #2 of 3 (permalink) Old 07-14-2010, 10:01 AM
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
If you do clean the MAF, make sure you use CRC MAF Cleaner. Be sure you clean the MAF without touching the SUPER SENSITIVE WIRE. CEL will come on if you use too low an Octane, your Gas Cap is loose or you have other Engine problems. Go to Autozone and they will pull the code(s) for FREE. It may be an actual physical problem or a simple solution.
Charles
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
post #3 of 3 (permalink) Old 07-15-2010, 05:36 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
Did you use the throttle manually while under the hood, I was told never to do that since it could set a code.
Peter Guenther is offline
    Oil and filter change plus air etc Bazzle R170 SLK-Class 32 11-26-2011 09:31 PM
    Oil / Air Filter Change - 2005 SL500 db2001 R230 SL-Class 2 05-31-2010 07:35 AM
    C240 Oil Change, Air Filter change atiqraza W203 C-Class 4 04-29-2010 10:27 AM
    Thinking of changing the air filter to K&N anyone ever change it to this one?? 1992300SL R129 SL-Class 30 11-11-2009 06:48 AM
    Just did my Oil change & air filter change. What else does Service B entail? RaleighMB W210 E-Class 5 03-07-2009 06:39 PM
