Throttle linkage W126 with 617 engine - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-11-2010, 07:57 AM Thread Starter
Date registered: Jun 2010
Vehicle: 1982 300 SD
Should I be concerned about the wear of the groove/slot on the linkage mounted on top to the valve cover? The pin that slides in the slot has a roller (i think) on it's tip. Looks like the roller has stopped rolling causing the groove/slot to wear. Should I replace it?
Thanks in advance for any help.
blobulent is offline
    I need help with the Throttle Linkage redline808 W123 E,CE,D,CD,TD,TE Class 2 07-01-2010 07:26 PM
    Throttle Linkage fodorizzi W203 C-Class 8 04-08-2009 11:40 PM
    Throttle Linkage Weather Man R/C107 SL/SLC Class 2 03-06-2009 07:54 AM
    Throttle Linkage neemhakim W123 E,CE,D,CD,TD,TE Class 4 09-06-2007 01:31 PM
    throttle linkage elgatoensombrero W123 E,CE,D,CD,TD,TE Class 3 01-25-2006 10:40 PM
