ABC Suspension issue, finally happened to me :( - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-09-2010, 09:57 PM Thread Starter
Date registered: Nov 2009
Vehicle: 2001 S55 AMG
So, after reading numerous threads on ABC failure, here I go now. I have an S55 2001, with 140,000 miles.
I've searched and know a bit about this problem, and will be taking the car in on Monday...but can anyone give me an idea as to what happened/price to fix?
Here it is: I was driving, and stopped at a gas station. About 1 minute after I stopped, I hear a crack, and immediately hydraulic fluid starts to gush out of the car and leak all over the place, like massive amounts of it. The red "ABC Drive carefully" light came on, the car is still the same height.
I did not drive it at all, and immediately called a flat bed truck, and had it towed to my house. Now what exactly happened? What could that "crack" sound be? Am I in for a big repair?
I know this topic gets repeated, but I did not find the answer to this specifically so I'd appreciate so comfort/insight while I nervously await what can happen!
crashtest is offline
post #2 of 7 (permalink) Old 07-10-2010, 03:39 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
Here's a drawing of the hydraulic components in your ABC.
The crack you heard could be from the fracture of a hydraulic line anywhere in the system. Or maybe a seal on one of the 4 struts or the valve units. With the car up on a hoist it will be easy for a tech to find the failing component.
keyhole is offline
post #3 of 7 (permalink) Old 07-10-2010, 06:16 AM
eric242340's Avatar
Quoted: 296 Post(s)
The crack you heard was the main pipe from the ABC tandem pump bursting and it used to be a common problem, they have since been reinforced to avoid this unpleasant happening. When the pipe goes, it goes with a crack or a pop sound but very loud.
ERIC.
eric242340 is offline
post #4 of 7 (permalink) Old 07-10-2010, 04:29 PM Thread Starter
In 2007 the recall was done on my car, and the new hose put in place - but I guess it cracked anyway! The back of the car is now on the rear tires, is that normal because all of the oil leaked out? Or is it more broken than I thought?
I'm taking it in monday via flatbed...hopefully it won't be a horrible bill, I'm taking it to an indy that I use often.
post #5 of 7 (permalink) Old 07-14-2010, 04:36 PM Thread Starter
Well, I got it figured out and fixed. Apparentely one of the hoses going to the back of the ABC suspension gave out, and that's what caused this. Everything else is fine.
Total cost to fix: $270 with labor and parts. I'm relieved!
post #6 of 7 (permalink) Old 07-14-2010, 10:58 PM
2010B180's Avatar
Date registered: Mar 2010
Vehicle: 2010 B180
that is not bad - $270 all in. the flatbed cost more ??
2010 B180 CVT
Saturn Red
2010B180 is offline
post #7 of 7 (permalink) Old 07-15-2010, 06:19 AM Thread Starter
I have roadside assistance, so the toll truck didn't cost anything.
    ABC/PS pump leaking causing ABC suspension severe drop 2003 s600 W220 S-Class 16 07-03-2012 04:54 PM
    It Finally Happened to me... TimsML430 W163 M-Class 8 05-31-2010 01:02 PM
    It has finally happened....... cisaacson W210 E-Class 4 03-26-2008 06:43 AM
    OT: It finally happened. Bogie W163 M-Class 15 06-20-2007 08:18 PM
    it finally happened to me..... ed W163 M-Class 7 10-12-2002 09:37 AM
