W210 Heater - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-09-2010, 05:41 AM Thread Starter
Date registered: Mar 2010
W210 Heater
Hi all, W210 E240 v6. Heater stuck on full hot, not very nice in summer. Any ideas on where I start to sort it out?
candhdyas is offline
post #2 of 4 (permalink) Old 07-11-2010, 08:56 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
post #3 of 4 (permalink) Old 07-12-2010, 12:10 PM Thread Starter
Originally Posted by leapyfish View Post
Welcome Hugh,
I cant help
have you looked in the vehicle specific areas http://www.benzworld.org/forums/
Many thanks for your reply, two other members replied in the W210 forum and helped me solve the problem at no cost - Great. Just shows you the power of the Forum.
post #4 of 4 (permalink) Old 07-12-2010, 12:49 PM
Date registered: Jul 2010
The duo-valve is located in the engine compartment on the right fender well back toward the firewall. It has 1 hose coming into it from the aux water pump and 2 hoses going out and into the firewall to the heater core. The valve uses electromagnets inside and are prone to sticking in the full open position. Give the silver metal servos on top of the valve a tap with a rubber mallet to see if it frees them up. If they are completely stuck replacement will be neccessary. Part# 004-830-20-84 $216.00 (U.S.)
Happy Wrenching!
Dookie is offline
    w220, Park Heater, webasto, auxiliary heater Ardjoakim W220 S-Class 0 07-11-2009 02:13 AM
    Some issues on a W210 E 320 CDI T, heater and diesel smell matzhinrichs General Mercedes-Benz 4 01-13-2009 10:01 AM
    E-Class (E300 TD) W210 Heater Control Problems rjsdavis W210 E-Class 1 09-10-2007 09:25 AM
    mercedes e240 w210 1998 saloon bulb replacement on air con / heater liver1234 W210 E-Class 4 10-28-2006 11:49 AM
    W210 Heater Direction Problem Telewest W210 E-Class 3 12-29-2005 02:07 PM
