1989 420SEL FRESH AIR RECIRCULATING SERVO - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-07-2010, 09:19 PM Thread Starter
Date registered: Jul 2010
Vehicle: 1989 420 sel & 1998 S500
LAST MONTH I BOUGHT A 1989 420SEL . ITS IN GREAT CONDITION AND SO FAR ALL I HAD TO CHANGE IS THE ANTENNA MAST . ONLY THING IM NOT SURE IS IF THE FRESH AIR RECIRCULATING SERVO IS WORKING PROPERLY. AC IS COLD ,UPPER & LOWER VENTS ,DEFROST, CLIMATE CONTROL & HEAT ALL SEEM TO WORK RIGHT . THE RECIRCULATING SWITCH LIGHTS UP WHEN PUSHED ON , BUT OUTSIDE SMELLS STILL COME IN . ALSO THE REAR VENT BLOWS COLD AIR BUT NO HEAT. WHEN ALL IS OFF AND CAR IS MOVING FRESH AIR FLOWS LIGHTLY FORM REAR VENT.
ARE THESE SYMPTOMS RELATED TO THE SAME PROBLEM??
IM THINKING THE OUTSIDE AIR VENT IS STUCK OPEN OR IS THIS IS HOW THE SYSTEM WORKS
AIR TEMP HERE IS IN THE 60S AND I SET IT ON AUTO .
THANKS
89benz is offline
post #2 of 2 (permalink) Old 07-11-2010, 08:45 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 6 Post(s)
leapyfish is offline
    I need a diagram to replace servo for recirculating door 22350 W126 S,SE,SEC,SEL,SD,SDL Class 19 08-18-2009 05:20 PM
    Air con/Heater only blows in the recirculating mode fifalex W124 E,CE,D,TD Class 5 08-04-2009 06:20 AM
    Recirculating air flap help please Ashv8 General Mercedes-Benz 0 10-14-2008 01:11 PM
    Recirculating air flap. Ashv8 General Mercedes-Benz 0 09-18-2008 12:08 PM
    Recirculating Air louver not louvering Chris Ball G-Class 0 08-05-2003 01:29 PM
