E320 with check engine light! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-06-2010, 12:04 PM Thread Starter
Date registered: Jun 2010
Hi all,
I had engine codes P0130 and P0133 come up when I went to Autozone to see why my check engine light came on. The corresponding report said to replace to O2 sensor (bank 1, sensor1). With your assistance, I replaced the left side rear O2 sensor. The check engine light went out, but it returned to "service engine in 100 miles". At the end of the 100 miles, the check engine light will come back on. The car has about 80,000 miles. I just purchased it. Any ideas? My local dealership wants to hit me up for $300 just to diagnose the problem, but they will credit that toward any repair work. Did I mention I just brought it. Thanks in advance for any help! A little short in Ohio. Woody
King SVELT is offline
post #2 of 3 (permalink) Old 07-06-2010, 12:10 PM
Kajtek1's Avatar
Quoted: 1070 Post(s)
Service engine is calling for regular service and should not trigger CEL. At least that is how it works on my car and not knowing your model I can only guess?
Get the scanner again and check what is it?
Change the oil in the mean time and reset the FSS.
Kajtek1 is offline
post #3 of 3 (permalink) Old 07-06-2010, 12:56 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Those "codes" are often pretty crude indicators of the problem at hand.
For example if your exhaust mixture is something the O2 sensor can't handle, the error will indicate exhaust sensor but the problem is probably instead MAF sensor. This is VERY common on M112/M113 engines.
Kent Christensen
'07 GL320CDI
lkchris is offline
    How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
    Check Engine Light E320 sbmace23 W124 E,CE,D,TD Class 13 06-18-2006 12:36 PM
    94 E320 Check Engine Light Jolinie General Mercedes-Benz 2 01-19-2006 03:09 PM
    E320 "CHECK ENGINE" light klym22 General Mercedes-Benz 2 10-28-2004 03:44 PM
    Check Engine Light on 95 E320 Guest (MBNZ) W124 E,CE,D,TD Class 3 08-05-2002 11:01 AM
