John Lay - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-01-2010, 11:34 AM Thread Starter
Date registered: Jul 2010
Question John Lay
I have a 1977 MB 350SL. I have continual problems with slow running where the engine keeps hunting and cutts out at low RPM. The following have been changed, plugs, leads, fuel pump, fuel distributor, timing adjusted, distributor checked and cleaned, good spark and fuel pressure. I suspect it might be some sort of electrical problem. Can any one shed any light on the problem or have had similar problems. Thanks
John lay is offline
    As I lay dying Botnst Off-Topic 8 10-24-2009 05:06 AM
    lay it on me... mountainredneck W124 E,CE,D,TD Class 5 03-29-2009 05:05 PM
    I'll just lay down and die now........ ThrillKill Off-Topic 7 02-09-2007 05:19 AM
    Kenneth Lay is DEAD jupiterpbc Off-Topic 25 07-06-2006 03:56 PM
    Best way to lay wires? JamesDean W126 S,SE,SEC,SEL,SD,SDL Class 11 04-27-2005 03:10 AM
