'83 300TD turns, doesn't start - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-22-2010, 07:19 AM Thread Starter
Date registered: Jun 2010
Hi all, I bought this car on Sat with 220k miles. What I wasn't informed of until after I paid was that the car was sitting for at least two years. Anyway, it started like a charm the first time (I made sure the engine was cold when I tried) and I drove it back to my house (about a 2 hour drive, car started off really slow, even for a diesel, but after about 30 minutes, it ran great).
After letting it sit overnight, the car would not start the next morning. It turns but nothing else. I searched some of these forums, used the manual fuel pump, and viola, it started. So I was thinking that it is a fuel problem. So, I replaced the fuel filters, changed the oil, replaced the oil filter, checked all fluids. Again, the car wouldn't start. I used the manual pump again (to make sure there was no air in the lines), the car started. I again let it sit overnight, and this AM the car would not start.
I am going to replace the glow plugs (the light on the dash goes out after about 5-10 secs so I don't think they are broken). What else do you think could be a problem? I don't really know how to check the compression but, I got the car to also learn how to fix it on my own.
All help is appreciated!
thh204 is offline
post #2 of 3 (permalink) Old 06-22-2010, 07:45 AM
Kajtek1's Avatar
Quoted: 1059 Post(s)
Don't replace glow plugs without testing them bad.
Your description clearly indicate that you have leaks in fuel lines and overnight the air enters the system.
What first time diesel owners don't realize is that fuel system on those engine runs on vacuum till it reaches the pump. Meaning leak will not show as a fuel outside, but as an air inside.
Make sure all the fuel connections are in good condition. From my memory you engine has connectors with copper washers. You might want to buy new ones and replace them. Also there is a clear tubing on the line that allows for observing air bubbles. If it turned brown -it would be good time to replace it as well.
Good luck and welcome to the forum.
Kajtek1 is online now
post #3 of 3 (permalink) Old 06-22-2010, 08:25 AM Thread Starter
Thanks, Kajtek. I will check out those lines. I know for a fact that there is a leak in one of the fuel lines. As I was replacing the secondary fuel filter, I noticed that one of the tubes was in pretty awful condition (gashes in the tube). After I restarted the car, a sizeable leak appeared in that tube.
Do I have to specially order that tubing, or can I get it from an Advanced Autoparts store? (Or could I even order it from somewhere like McMaster?)
Thanks for the info!
thh204 is offline
    300d turns over, but no start. jessesaur W123 E,CE,D,CD,TD,TE Class 63 01-17-2010 02:42 PM
    '84 300TD stalls after turns - only on highway MarieGraham W123 E,CE,D,CD,TD,TE Class 9 07-07-2009 06:56 AM
    300 E turns over but won't start Ann Harrison W124 E,CE,D,TD Class 10 07-30-2008 07:06 AM
    300 E turns over but doesn't start Ann Harrison W124 E,CE,D,TD Class 2 07-27-2008 07:05 PM
    Always two turns to start Guest (MBNZ) W124 E,CE,D,TD Class 3 07-02-2002 09:54 AM
