The Fan Belt - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-21-2010, 03:19 AM Thread Starter
Date registered: Jun 2010
Vehicle: C240 classic, C230 coupe
The Fan Belt
Good day All! Where can I find a diagram of the fan belt "layout" for a mercedes "classic 1998 model (box'er shape)". We stripped the belt whilst driving, have purchased a replacement from the dealer, but don't quite know the path the belt should follow!! Is there a site that shows where the belt should be threaded?
Many thanks, it was fantasic to stumble upon this site!
Alan
eagleswraith is offline
post #2 of 4 (permalink) Old 06-21-2010, 09:11 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 381 Post(s)
Hi
You're going to have to tell us what engine and model you refer to here, as this is the General M-B forum. There are many referred to as 'classic'......
keyhole is offline
post #3 of 4 (permalink) Old 06-21-2010, 10:37 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Diagram is usually in owners manual.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #4 of 4 (permalink) Old 06-21-2010, 05:33 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
All good points.
If you are being consistent with both "classic" references in your profile and your post, then you're talking about the C240, which would be the V6 M112. Below is the layout for that routing.
However, it's rare that belts just fail, so carefully inspect the various rotating accessories and pay special attention to the idler pulley, tensioner and harmonic balancer. Replace any that are not up to snuff, or you'll be doing this again (and perhaps more!) quite soon.
Good luck.
Check Codes is offline
    Fan belt emman W168 A-Class 6 01-03-2009 04:21 AM
    fan belt (V-belt) life? benzwag W126 S,SE,SEC,SEL,SD,SDL Class 7 02-01-2008 07:18 AM
    Fan Belt wvh187 W201 190-Class 3 08-02-2007 10:39 AM
    Fan Belt Braingears G-Class 2 04-10-2006 09:39 AM
    Help with Fan Belt Brian Felts W124 E,CE,D,TD Class 1 10-23-2005 09:44 AM
