Oil change on a 2007 ML350 - Page 3 - Mercedes-Benz Forum
post #21 of 22 (permalink) Old 06-22-2010, 01:24 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 343 Post(s)
Originally Posted by JoeVal View Post
The Mobil 1 (ESP) 5W30 meets only MB spec 229.51, meaning it is only for diesel engines and should not be used in gasoline engines due to its low sulfur content.
JoeVal: Is low sulfur the same as low ash?
Mobil engineers do not confirm that it is a problem to use 229.51 in a petrol engine. See forum Q & A here:
Benefits of a Low Ash Motor Oil
keyhole is offline
post #22 of 22 (permalink) Old 12-07-2012, 08:45 AM
Date registered: Aug 2010
I think I know what happened to you. I made a mistake when doing my oil change myself, and had similar results and mess after a much shorter drive. Your local shop may have made the same mistake. The cap over the oil filter has two grooves that both can fit the very large O-ring. I mistakenly put the O-ring in the top groove (the one closer to the top of the cap). Bad mistake. Oil all over the front of the engine compartment after only 3 miles. On the 2007 ML350, the large O-ring goes in the lower groove of the two. Hope others can learn from my mistake...
avanwor is offline
    ML350 Oil Change Procedure Paul S8 ML350 W164 M-Class 36 10-25-2015 05:32 AM
    Check oil on next refueling .. 2007 ML350 tedqnmb General Mercedes-Benz 4 02-06-2008 01:54 AM
    Oil Change Interval on ML350 videopete W163 M-Class 9 12-15-2007 04:00 PM
    2007 ML350 OIL FILTER KENNETHMD W164 M-Class 2 08-20-2007 03:55 AM
    ML350 Oil Change Questions EWALD W164 M-Class 9 12-24-2006 05:42 PM
