Rough Cold Idle-CRC MAF CLEANER - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 06-18-2010, 11:39 PM Thread Starter
1e320's Avatar
Date registered: Apr 2010
Vehicle: 2002 E320 Special Edition
I had a post not long ago because my code reader was showing P0106. This was for the MAP sensor and the CEL was on. With forum help I installed the Map sensor, reset the code and everything seemed OK. There was no CEL but I had an idle problem when the engine was cold. It idled rough and would almost cut off until proper operating temp. was obtained. I read in this forum to purchase CRC MAF Sensor Cleaner. I bought the CRC, removed the MAF and hosed it down with the CRC in every nook and cranny. It dries almost immediately. BUT, my car is cured from the idle problem and actually feels as if I just got a major tune-up. It idles so smooth, it is unbelievable. It appears that I am getting close to +2 mpg. The trans even feels as if it is shifting smoother. My wife noticed it so much I will be doing her MAF on her Caddy CTS.
I just wanted to write this so people will try it BEFORE replacing the MAF. I was about to replace the MAF but the CRC made the car run as good as new. It really doesn't cost that much either. I paid $6.66 at Auto Zone.
Just thought I could get people to try this BEFORE buying a new MAF.
2002 E320 Special Edition-Quartz Silver/Ash
1e320 is offline
    Rough Cold Idle-CRC MAF CLEANER 1e320 W210 E-Class 1 06-19-2010 12:35 AM
    Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 10 03-22-2010 11:28 PM
    rough idle after throttle body cleaner? slowfncar W202 C-Class 4 03-09-2010 05:02 PM
    rough idle, MAF?? lextoy35 C208/A208 CLK-Class 7 10-27-2009 03:37 PM
    Testing out CRC Mass Air Sensor Cleaner... omeyhomey W210 E50 AMG, E55 AMG 17 05-16-2007 07:18 AM
