asr/bas fault light 1999 c180 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-17-2010, 03:08 PM Thread Starter
Date registered: Jun 2010
Unhappy asr/bas fault light 1999 c180
can anyone help me here, i have a c180 1999 with fault light on for asr/bas and abs it comes and goes but lately its on, also when it is on the automatic central locking when driving does not activate, you can lock the doors using the central lock button on dash.
battery voltage looks ok.
I had a guy try to put diagnostic on but said no power at connector for diagnostic?
alkane is offline
post #2 of 3 (permalink) Old 06-17-2010, 04:44 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
It may be a broken "brake light switch" that many people had. On my 99 E430, the brake light switch got 4 pins. Your car's brake light switch got 6 pins that may explain why the central lock does not work. Cruise control should not work either when ABS... warning light is on. The switch is located above the brake pedal, you need to remove the cover to get to it. Go to the forum for your car model, search for "brake light switch" to find fixing details.
Dealer may charge $200 for part and labor. If you got the time, order the switch from (~$15) then replace it yourself.
Credit should go to the member who posted the fix for the problem. He/she saved the MB world millions of bucks.
mbvis is offline
post #3 of 3 (permalink) Old 06-19-2010, 01:50 PM Thread Starter
thanks for that reply will get my mechanic to check it out.
alkane is offline
    BAS/ASR & ABS light simultaneously came on today. 1999 S320. W140FTW W140 S-Class 23 01-07-2015 07:22 AM
    1999 s320 bas asr lights on after jiffy lube HELP bradleyjason General Mercedes-Benz 7 05-24-2010 05:26 PM
    BAS/ASR light on omega1_95 C208/A208 CLK-Class 4 10-27-2005 02:23 PM
    My BAS and ASR light come on. Pej D. R170 SLK-Class 3 08-25-2002 02:43 PM
    E300td 1999 ASR&BAS error notification Guest (MBNZ) W210 E-Class 2 07-05-2002 04:00 PM
