EZS Removal Help - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-17-2010, 03:20 PM Thread Starter
Date registered: May 2010
Vehicle: Mercedes C220 CDi Avantgarde Saloon Auto
EZS Removal Help
Can someone offer some help please. MB want a stupid amount of money to replace my ignition EZS that is playing up. On the web I have found a website that can repair the whole unit but I have no idea how to remove it. I took out the instrument cluster thinking I might be able to get to it however there is a plastic case surrounding access. Does anyone know how I access the ignition lock to remove the EZS or the whole unit. Thanks
aims is offline
post #2 of 9 (permalink) Old 06-18-2010, 03:51 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
the ring around the front of the eis holds it in place. there is a special tool to remove it, the ring has notches in it that corrospond to the special tool. if your strong enough you can turn it or use a screwdriver but will damage it.
Streetglower is offline
post #3 of 9 (permalink) Old 06-18-2010, 10:33 AM Thread Starter
Sorry about my stupidity but once I remove the ring does the unit slide out of the slot where the key is instered ? Seems quite a small hold for a pcb to be pulled out of ?
aims is offline
post #4 of 9 (permalink) Old 06-18-2010, 09:13 PM
waybomb's Avatar
Date registered: Apr 2005
Vehicle: 2005 S55; 2003 ML350; 2002 C240; 1997 C280 Sport; 1991 300SL; 1986 190e 2.3 16V (2); 1968 W30 442
Quoted: 9 Post(s)
Sorry for butting in - but what is the EZS and the EIS?
Thanks!
Fred
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
1988 46' Cougar US1 with Triple blown 572s
http://s4.photobucket.com/albums/y145/waybomb/
Warming the Globe, 24 Cylinders at a Time
Point me to a 126 wagon in the States PLEASE!
waybomb is offline
post #5 of 9 (permalink) Old 06-19-2010, 02:05 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
EIS = Electronic Ignition Switch = EZS = Elektronischer Z√ľndstartSchalter
Diesel Benz is offline
post #6 of 9 (permalink) Old 06-19-2010, 05:09 AM
Quoted: 4 Post(s)
no it doesnt just come out, it either has to be pulled out from the bottom of the dash or through the cluster area. each car is different.
post #7 of 9 (permalink) Old 06-19-2010, 10:51 AM Thread Starter
Thanks for the help. So I use the tool to loosen the ring then the module will freely pull out from underneath or the dash.
aims is offline
post #8 of 9 (permalink) Old 09-28-2010, 09:29 AM
Date registered: Sep 2010
Hi, I have had a similar problem with the EZS. Which is the "web site" that can repair it? Thanks!
antawaya is offline
post #9 of 9 (permalink) Old 09-28-2010, 10:54 AM
Kajtek1's Avatar
Quoted: 1167 Post(s)
WARNING. I had to deal with ignition on 97 model that had blade key with electronic chip and MB is having ingenious blockade mechanism. With any tampering the blockade goes into permanent lock and the only solution seems to be cutting it off, what is lot of work. One member in W210 posted a trick how to reset the blockade, but it is ... tricky.
So I assume the EZS is having similar blockade and what seem as easy job might easily turn into disaster.
Don't even touch the ignition unless you fully understand what you are doing, or better cut your leg and take it to the dealer.
Kajtek1 is online now
    cab removal/ head removal/ hydraulic install/ esde Unimog 25 03-28-2010 05:33 PM
    fuel strainer removal in wagon/chrome removal rfbordeaux W123 E,CE,D,CD,TD,TE Class 2 08-13-2009 08:31 AM
    Steering wheel button removal & Headlight bezel removal tomard W220 S-Class 9 04-29-2009 03:46 PM
    Unlock door Problems, Cold Time, EZS!? - Help! ypt W203 C-Class 1 01-18-2009 06:08 PM
    Transmission Removal 1988 300TE/E W124 - Tips on removal, replacing shaft seals, etc. GermanCarNut W124 E,CE,D,TD Class 0 11-20-2006 03:15 PM
